How to Fix Broken Powder Make-up
  1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
  2. How to Fix Broken Powder Make-up: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Broken Powder Make-up: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Broken Powder Make-up: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pour a small amount of rubbing alcohol into the cap.
    • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
    • Do not use more than two caps worth of rubbing alcohol.
  3. How to Fix Broken Powder Make-up: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Broken Powder Make-up: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
  4. How to Fix Broken Powder Make-up: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
  5. How to Fix Broken Powder Make-up: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
    • If the powder is not fully dry, let it sit for another hour and continue to check back.
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
Meghan Smith
crwdns2935283:004/09/15crwdne2935283:0
224 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 30-3, Green Spring 2015 crwdns2935289:0Cal Poly, Team 30-3, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S30G3
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,833
