How to Fix A Crooked Cabinet Door
  1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the cabinet door, and determine where it is misaligned.
  2. How to Fix A Crooked Cabinet Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-attach the hinge into place.
    • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
    • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
  3. How to Fix A Crooked Cabinet Door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
    • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
    • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
    • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
  4. How to Fix A Crooked Cabinet Door: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The result of the tightened hinge will look as pictured.
  5. How to Fix A Crooked Cabinet Door: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
    • The result should look as pictured.
Camrynne Paul
crwdns2935283:003/19/22crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 4-44, Briggs Spring 2022 crwdns2935289:0CSU Los Angeles, Team 4-44, Briggs Spring 2022crwdne2935289:0
CSULA-BRIGGS-S22S4G44
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 10,601
