This guide will show you how to fix the “Staingate” issue on Apple MacBook displays. Staingate happens when the anti-reflective coating on certain models of MacBook displays begins to delaminate and wear off, causing a stain-like appearance that is noticeable when the screen is off, on a low brightness setting, or when sunlight is hitting the screen. Staingate is a very widespread issue, and many people unfortunately end up replacing the display or even the entire MacBook because of it. This guide will fix the Staingate issue and make the display look brand new.
crwdns2935267:0crwdne2935267:0Microfiber Cleaning Cloths$3.99
Dampen a microfiber cloth with water.
Use the cloth to clean the screen of dust and debris.
Put on latex gloves.
Dampen a separate microfiber cloth with Listerine or white vinegar.
Wipe the screen with the damp vinegar/Listerine cloth in a circular motion.
You may have to wipe the screen a second time as some stains can be stubborn.
Apply more Listerine or white vinegar onto the cloth as needed.
Dampen the first microfiber cloth with water again.
Wipe the screen free of debris with the cloth.
Install the new screen protector on your MacBook screen to minimize glare and to get some of the anti-reflectiveness back.
Staingate should not occur again as long as you install a reputable screen protector afterwards.
crwdns2935229:027crwdne2935229:0
crwdns2947412:025crwdne2947412:0
Ist es möglich, das Glas auszubauen? Ich habe ein MacBookPro11,4 – MacBook Pro (Retina, 15', Mitte 2015).
Followed instructions provided and used cleaning vinegar. Took a while and repeated rubbing of some areas with fresh vinegar, but end result very good and screen as new. Only in two bottom corners either pressed too hard or got some fluid behind the glas that shows up on the display with different “wet” colors. Hope that over time - if it is fluid - this will evaporate/disappear. But still happy with results as it so much improved. Thanks for sharing this approach.
Can confirm that few days later the “wet” colors in bottom corners have completely disappeared. This approach completely fixed the “staingate” issue for us. Thanks.
Thanks for the instructions! Works perfectly on our MBP early 2015.
Sue and Sergio
Thank you for the instructions! Just got my hands on a 2017 MBP so looking forward to trying this fix.
Does anyone have a recommendation for a reputable screen protector with anti-glare and anti-reflective properties?
