How to Enable developer mode on Chromebook
Jacob Mehnert
crwdns2944109:0crwdnd2944109:0Jacob Mehnertcrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0May 8, 2024crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
If you want to push your Chrome device beyond its typical capabilities, then you're going to want to enable developer mode. This is the same as gaining root access on your android device, and gives you significantly more control over your Chromebook. You can do things like side load Android apps or even install a different operating systems onto your chrome device.
    • Enabling or disabling developer mode will wipe your Chromebook. Your device will be Powerwashed, which means that any accounts and their files will be removed from the device. If you store your data online, then you can log on with the same account afterwards.
    • Officially Google does not offer support for developer mode since it is intended for developers. Enabling developer mode will void most warranty's, so if you encounter a hardware error, disable developer mode before getting warranty support.
    • To enable developer mode, you will need to deactivate OS verification. Only turn this on if you are sure of what you are doing!
    • On some older Chromebooks, Developer Mode could be turned on with a physical switch that could be flipped. However, on newer devices you will need to boot the device into Recovery Mode.
    • To start, make sure your Chromebook is on. Then press the Esc and Refresh keys and then press the power button.
    • Normally the refresh key is where the F3 key would be, and is normally the fourth key from the left on the top most row on a keyboard.
    • Your device should take you to a screen that says something along the lines of "Chrome OS is missing or damaged", signifying that you have arrived at the recovery screen.
    Ça ne fonctionne pas quand j'appuis sur la touche esc et refresh....et ni la tous esc et agrandir que faire ?
    Mochi - crwdns2934203:0crwdne2934203:0
    Which model of Chromebook are you trying to put into developer mode?
    Jacob Mehnert -
    Instale chrome flex en una lap nativa de windows y no puedo entrar a la pantalla de recuperacion
    ozkr vzkz - crwdns2934203:0crwdne2934203:0
    No puedo y lo he intentado todo
    Naty Naty - crwdns2934203:0crwdne2934203:0
    • Once you're at the recovery screen, press the Ctrl and D keys.
    • You'll see a screen that says " To turn OS verification OFF, press ENTER". Press enter to enable developer mode.
    • You will see a screen that indicates that OS verification is OFF. (If left long enough the device should beep at you.)
    • This screen is a security feature, as the developer mode doesn't have the usual security features. The screen is meant to help the normal user by guiding them through the process of disabling developer mode if they didn't mean to enable it.
    • To boot your device press the Ctrl and D keys again. Your device should boot automatically and will prepare your system for developer mode (This can take up to 15 minutes.
    A cet étape quand j’appuie sur entrée mon chrome redémarre mais sa revient toujours à l’os manquant
    Diak - crwdns2934203:0crwdne2934203:0
Congratulations! You now have full and unrestricted access to your Chromebook. If you wish to access a root shell press Ctrl, Alt, and the T keys to open the Crosh shell. From their type shell. You can use this to run commands with the sudo command to run commands with root access.
If you want to return to the standard mode, simply reboot your device and at the warning screen, simply press the space key as prompted. Your device will revet to the factory-default and will erase the files.
crwdns2935229:035crwdne2935229:0
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
39.733 crwdns2915208:0crwdne2915208:0
crwdns2935297:050crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:061crwdne2931471:0
crwdns2935297:0195crwdne2935297:0
crwdns2947412:08crwdne2947412:0
the divces owner had turned of developer mode how can i fix this fo
lenovo thinkpad e11 chromebook
Fadi Naddi - crwdns2934203:0crwdne2934203:0
The process for disabling developer mode is very similar to enabling it. Turn off your device and turn it back on. When the Chromebook boots and displays the OS verification message, press the Spacebar. This will factory reset the device and return it to its standard configuration.
Jacob Mehnert -
Merci, pour le guide alor si cette manipulation (Esc et Refresh, puis appuyez sur le bouton d'alimentation) n'affiche pas l'écran de récupération. Que faire?
Divin - crwdns2934203:0crwdne2934203:0
Selon l'âge de votre appareil, la combinaison de touches peut être différente. Sur certains modèles de Chromebook, vous devez appuyer sur les touches Échap et Agrandir et les maintenir enfoncées, puis appuyer sur Alimentation.
Jacob Mehnert -
What if the last Ctrl+D is not doing anything
Ava Lemburg - crwdns2934203:0crwdne2934203:0
As in you cannot get past the recovery screen, or you cannot get past the screen saying that OS verification is off?
Jacob Mehnert -
Les deseo lo mejor por la sabiduría que entienden y por lo mucho que ayuda gracias les deseo lo mejor.
Loveido - crwdns2934203:0crwdne2934203:0
No puedo iniciar en modo desarrollador me pide que vuelva a modo administrador que puedo hacer ?
Cristopher Moya Perez - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 70
crwdns2936753:07crwdne2936753:0 431
crwdns2936753:030crwdne2936753:0 1,986
crwdns2942667:0crwdne2942667:0 69,244
