How to Enable TRIM Support
  1. How to Enable TRIM Support, How to Enable TRIM Support: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Enable TRIM Support, How to Enable TRIM Support: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Enable TRIM Support, How to Enable TRIM Support: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Launch Terminal.
    • Do a search with the "Spotlight Search" or go to "Applications / Utility" to launch the "Terminal".
  2. How to Enable TRIM Support: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Enable TRIM Support: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the Terminal insert the following command line:
    • sudo trimforce enable
    • To disable TRIM, the command is as follows : sudo trimforce disable
    • Press the [return] key.
    • Enter your Mac's user password.
    • Your password will not be displayed when typing, but it is there
  3. How to Enable TRIM Support: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Enable TRIM Support: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press "y" and press "return" key to accept.
    • Press again "y" and press "return" key to accept.
    • Warning your computer will restart.
  4. How to Enable TRIM Support: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations! TRIM support is activated.
Congratulations you have enabled TRIM support in macOS.
crwdns2935229:024crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Anthony Fassler
crwdns2935283:002/26/15crwdne2935283:0
6,853 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
Merci pour ce petit tuto bien sympa. simplement (et je ne voudrais pas dire de bêtises) je crois que le trim sous mac os 11 (big sur) n’est plus possible
au sens ou s’il est activé il pose de Gros problemes au systeme.
jeff - crwdns2934203:0crwdne2934203:0
Bonjour jeff,
J’ai fait ce tutoriel, il y a quelques années ou les SSD étaient installés avec une partition Mac extended. Depuis, il y a APFS qui est sortie et Trim est devenu obsolète, car APFS gère mieux les fichiers que Trim.
Donc, ça n’a rien à voir avec Big Sur, mais je vais tout de même rajouter une mention au tutoriel.
Anthony Fassler -
Je ne peux lui donner 30, il y a faute de français. Trim n’est pas activer, mais bien activé
Michel Lavallée - crwdns2934203:0crwdne2934203:0
Bonjour j’ai l’intention d’installer un disque SSD dans mon iMac 27 pouces de 2019
Est-ce que j’ai besoin d’installer un capteur thermique ou une sonde thermique sur le disque SSD bonne journée merci
Bertuzzi - crwdns2934203:0crwdne2934203:0
J’ai l’impression qu’on ne peut répondre de manière catégorique à la question du TRIM. J’ai plusieurs iMac avec SSD Samsung 870 EVO en APFS (10.15.x, 11.6.x) et j’hésite vraiment à l’activer. Je lis trop de choses négatives, donc dans le doute, je ne le fais pas. Je retiens en lisant ailleurs que si le Garbage Collector du SSD fait son travail, activer TRIM ne devrait pas être obligatoire, seulement “recommandé”. Or ici le tuto dit le contraire… En réalité, j’aimerais connaitre la différence réelle entre la durée de vie d’un SSD récent avec et sans TRIM, car si c’est négligeable on arrête directement la discussion… Que va-t-il réellement se passer si on ne l’utilise pas à (très) long terme. J’ai vu que lorsqu’il est activé, les démarrages peuvent être lents, et que il pourrait par exemple de toute façon se désactiver lors d’une mise à jour ou d’un PRAM RESET… Surveiller perpétuellement l’activation du TRIM n’est pas possible sur la machine d’un client par exemple et là est mon plus gros problème.
PG89 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 404
crwdns2942667:0crwdne2942667:0 44,412
