How to Disconnect the Battery in the Samsung Galaxy A53 5G
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Heat the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Slice the adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Slice the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Slice the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Slice the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick at the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Remove the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Unscrew the motherboard cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  10. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Pry up the motherboard cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Pry up the motherboard cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Pry up the motherboard cover: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of an spudger into the gap between the frame and the motherboard cover on the right edge.
    • Use the spudger to pry up the motherboard cover.
  11. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Remove the motherboard cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard cover.
  12. How to Disconnect the Battery in the Samsung Galaxy A53 5G, Disconnect the battery cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Samsung Galaxy A53 5G, Disconnect the battery cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58 791 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 722crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 41
