Are you wondering why your Nespresso coffee is tasting off and doesn’t have that sufficient taste? Use this guide to learn how to descale your Nespresso VertuoPlus machine in an easy few steps.
Descaling your coffee machine is ultimately cleaning and stripping any excess dirt that has built up on the machine’s surface which could potentially cause your coffee machine to stop functioning properly and result in bad-tasting coffee.
Before using this guide, make sure you have the Nespresso descaling kit. Any other type of cleaning solution used in the machine could potentially break the machine.
Turn the machine on by pressing the button with a coffee mug logo.
Lift the lever upwards to remove any used capsules from the machine.
Empty the capsule container that is located at the back of the machine.
Turn the machine off by pushing the same lever down.
Fill the water tank with one unit of the Nespresso descaling liquid and add three cups of water to the solution.
Il est préférable de donner un volume en ml ou l et non en "tasse" qui est une unité tout à fait subjective : il existe de toutes petites et de grandes tasses. Laquelle utiliser ?
To access the descaling mode on the machine, push both the button and lever down for three seconds.
To access the descaling mode, press the lever down one time.
ATTENZIONE tutti i passaggi dove leggete “si ferma automaticamente” NON SONO VERITIERI. A fine serbatoio dovete premere voi il tasto tazzina per cambiare acqua e riprenderlo per iniziare il risciacquo . Dove voi premerlo di nuovo a fine ciclo e quindi abbassare levetta e pulsante x 3 secondi per uscire dalla modalità . Ciao. Livio
To start descaling, push the button.
Bonjour,
H'ai un problème a ce stade. En effet, après avoir clignote en lumière orange, le voyant devient rouge. La fonction détartrage n'est pas enclenchée. Que faire ? Merci
dite che la macchina si ferma automaticamente a operazione completata ma cosa vuol dire quando finisce l'acqua??????
Guarda la mia risposta al commento di Anna Puliafito, ho risposto anche a te, ho lo stesso problema e la mia soluzione è quella
Non esce acqua! Sono ore che è in modalità decalcoficazione ma spingo il tasto e non esce
A me è partita la decalcificazione solo una volta spinto il tasto in contemporanea con la levatta è per rispondere a Teresa Camerotto anche a me non si ferma da sola, poco prima che finisce l’acqua la rimbocco e non appena vedo che esce pulita la stoppo manualmente cliccando semplicemente il tasto, lavo il serbatoio, metto l’acqua “nuova” e poi avvio il risciacquo della macchina
Tasto arancio lampeggia da mezz’ora ma non succede nulla!
Fabio -
non è vero! per spegnere il ciclo di decalcificazione occorre premere il tasto una volta
Purtroppo la spia arancione continua a lampeggiare ma l’acqua dal serbatoio non viene aspirata e quindi non esce nulla e presumo la decalcificazione non è stata fatta. Cosa fare? Grazie
ma quando finisce l’acqua che si fa???
Empty the descaling liquid from the water tank.
Rinse and clean the tank thoroughly.
Fill the water tank with fresh water and place it back into the machine.
Push the button to rinse the machine.
stessa cosa, per interrompere il ciclo occorre premere il tasto una volta
a me non continua in maniera automatica cosa può essere ?
Ma è mai possibile che a causa di questa decalcificazione per altro già fatta ho una macchina da caffè da 190 euro ferma !!! Ma maledetti, ho comprato l’apposito prodotto , seguito pari passo le indicazioni , adesso oltre che a bloccarsi lampeggia due volte di rosso !!! Le ho provate tutte , se ripeto la decalcificazione eroga una volta e poi rimane il led arancio lampeggiante a vita senza far nulla ! C’è qualcuno sul pianeta che può dirmi come sbloccare questa macchina . Credo che sia più un problema di blocco “elettronico “ che meccanico … HELP !!!
Llana al servicio técnico. Si esta en garantía la recogen y te dejan una mientras revisan la tuya
To exit descaling mode, press both the button and lever at the same time for three seconds.
A green light will show, indicating the descaling has been completed successfully.
La spia che indica la decalcificazione da fare è ancora presente. Metà rossa e metà verde
Se la spia lampeggia rosso invece che verde cosa bisogna fare?
Risolto il problema ?
Come Concetta la spia rimane come prima..
Appena fatta la decalcificazione veloce e tutto ok
Grazie mille dell'aiuto è andato tutto a buon fine.
My machine did not switch to descaling mode after several tries. I ran it manually.
Istruzioni chiarissime. Grazie infinite
dopo aver completato l'iter di decalcificazione, è meglio fare un ciclo di pulizia semplice con acqua fredda, agire sul pulsante per 3 volte rapidamente.
al comando del ritornare in modalità x fare il caffè la spia verde mi è ridiventata subito rossa! cosa fare?
Desconecta por 15' y vuelve a enchufar a la corriente Haces un reset
Effettuato ora la decalcificazione come da indicazioni tutto a posto. Grazie
A mi nunca se me para automáticamente la descalcificación ni el enjuague.
Lo hago después de 1½ depósitos i salgo del paso
Acabo de hacerlo con èxito
A ciclo completato la spia è rimasta rossa e arancione. Cosa devo fare? Elena Pasquini
La spia rimane sempre rossa e arancione. Cosa fare in questo caso?
Per uscire nuovamente dalla modalità di decalcificazione, tenere premuti contemporaneamente il pulsante e la leva per tre secondi.
crwdns2935229:043crwdne2935229:0
crwdns2947412:012crwdne2947412:0
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
Buona sera Maria, hai per caso risolto? ho lo stesso problema!
Anche a me succede la stessa cosa...
I ran the descaling liquid through but the red light was still there.. what should i do?
Vado nelle funzione , eroga una volta si ferma e poi nulla , lampeggia sempre color arancione ma nulla di nulla , ma bisogna intervenire manualmente o avviene tutto in automatico ?
Dopo la decalcificazione compare nuovamente la spia metà rossa e metà verde. Come si può risolvere?
Have you tried the following?
To exit descaling mode again, press and hold the button and lever simultaneously for three seconds.
Hat prima geklappt 🤩vielen Dank!
Hervorrgend. Hat alles funktioniert
Hans Peter Aull - crwdns2934203:0crwdne2934203:0
Sehr gut, hat alles funktioniert
