How to Descale a Nespresso VertuoPlus
  1. How to Descale a Nespresso VertuoPlus, How to Descale a Nespresso VertuoPlus: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the machine on by pressing the button with a coffee mug logo.
    Hervorrgend. Hat alles funktioniert
    Hans Peter Aull - crwdns2934203:0crwdne2934203:0
    Sehr gut, hat alles funktioniert
  2. How to Descale a Nespresso VertuoPlus: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a Nespresso VertuoPlus: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a Nespresso VertuoPlus: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lever upwards to remove any used capsules from the machine.
    • Empty the capsule container that is located at the back of the machine.
  3. How to Descale a Nespresso VertuoPlus: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the machine off by pushing the same lever down.
  4. How to Descale a Nespresso VertuoPlus: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fill the water tank with one unit of the Nespresso descaling liquid and add three cups of water to the solution.
    Il est préférable de donner un volume en ml ou l et non en "tasse" qui est une unité tout à fait subjective : il existe de toutes petites et de grandes tasses. Laquelle utiliser ?
    Gilles Guérin - crwdns2934203:0crwdne2934203:0
  5. How to Descale a Nespresso VertuoPlus: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To access the descaling mode on the machine, push both the button and lever down for three seconds.
    • You will see an orange light, indicating that you have reached the "Special Functions" menu.
  6. How to Descale a Nespresso VertuoPlus: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To access the descaling mode, press the lever down one time.
    ATTENZIONE tutti i passaggi dove leggete “si ferma automaticamente” NON SONO VERITIERI. A fine serbatoio dovete premere voi il tasto tazzina per cambiare acqua e riprenderlo per iniziare il risciacquo . Dove voi premerlo di nuovo a fine ciclo e quindi abbassare levetta e pulsante x 3 secondi per uscire dalla modalità . Ciao. Livio
    Poccio71 - crwdns2934203:0crwdne2934203:0
  7. How to Descale a Nespresso VertuoPlus: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To start descaling, push the button.
    • An orange light will start to blink indicating the descaling function.
    • The machine will stop automatically when completed.
    Bonjour,
    H'ai un problème a ce stade. En effet, après avoir clignote en lumière orange, le voyant devient rouge. La fonction détartrage n'est pas enclenchée. Que faire ? Merci
    samir.ouasti - crwdns2934203:0crwdne2934203:0
    dite che la macchina si ferma automaticamente a operazione completata ma cosa vuol dire quando finisce l'acqua??????
    Teresa Camerotto - crwdns2934203:0crwdne2934203:0
    Guarda la mia risposta al commento di Anna Puliafito, ho risposto anche a te, ho lo stesso problema e la mia soluzione è quella
    Jhojana Carolina Ruiz -
    Non esce acqua! Sono ore che è in modalità decalcoficazione ma spingo il tasto e non esce
    Anna Puliafito - crwdns2934203:0crwdne2934203:0
    A me è partita la decalcificazione solo una volta spinto il tasto in contemporanea con la levatta è per rispondere a Teresa Camerotto anche a me non si ferma da sola, poco prima che finisce l’acqua la rimbocco e non appena vedo che esce pulita la stoppo manualmente cliccando semplicemente il tasto, lavo il serbatoio, metto l’acqua “nuova” e poi avvio il risciacquo della macchina
    Tasto arancio lampeggia da mezz’ora ma non succede nulla!
    Fabio -
    non è vero! per spegnere il ciclo di decalcificazione occorre premere il tasto una volta
    Anto Pido - crwdns2934203:0crwdne2934203:0
    Purtroppo la spia arancione continua a lampeggiare ma l’acqua dal serbatoio non viene aspirata e quindi non esce nulla e presumo la decalcificazione non è stata fatta. Cosa fare? Grazie
    Maria grazia Di liberto - crwdns2934203:0crwdne2934203:0
    ma quando finisce l’acqua che si fa???
    Pietro Frison - crwdns2934203:0crwdne2934203:0
  8. How to Descale a Nespresso VertuoPlus: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Empty the descaling liquid from the water tank.
    • Rinse and clean the tank thoroughly.
  9. How to Descale a Nespresso VertuoPlus: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fill the water tank with fresh water and place it back into the machine.
  10. How to Descale a Nespresso VertuoPlus: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the button to rinse the machine.
    stessa cosa, per interrompere il ciclo occorre premere il tasto una volta
    a me non continua in maniera automatica cosa può essere ?
    Angelo Cantatore - crwdns2934203:0crwdne2934203:0
    Ma è mai possibile che a causa di questa decalcificazione per altro già fatta ho una macchina da caffè da 190 euro ferma !!! Ma maledetti, ho comprato l’apposito prodotto , seguito pari passo le indicazioni , adesso oltre che a bloccarsi lampeggia due volte di rosso !!! Le ho provate tutte , se ripeto la decalcificazione eroga una volta e poi rimane il led arancio lampeggiante a vita senza far nulla ! C’è qualcuno sul pianeta che può dirmi come sbloccare questa macchina . Credo che sia più un problema di blocco “elettronico “ che meccanico … HELP !!!
    Llana al servicio técnico. Si esta en garantía la recogen y te dejan una mientras revisan la tuya
    Mercè Feliu - crwdns2934203:0crwdne2934203:0
  11. How to Descale a Nespresso VertuoPlus: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To exit descaling mode, press both the button and lever at the same time for three seconds.
  12. How to Descale a Nespresso VertuoPlus: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A green light will show, indicating the descaling has been completed successfully.
    La spia che indica la decalcificazione da fare è ancora presente. Metà rossa e metà verde
    concetta gravina - crwdns2934203:0crwdne2934203:0
    Se la spia lampeggia rosso invece che verde cosa bisogna fare?
    Loris Giuliani - crwdns2934203:0crwdne2934203:0
    Risolto il problema ?
    massimo.pasqualone -
    Come Concetta la spia rimane come prima..
    Gigetto Alto - crwdns2934203:0crwdne2934203:0
    Appena fatta la decalcificazione veloce e tutto ok
    Salvato Nicoletta - crwdns2934203:0crwdne2934203:0
    Grazie mille dell'aiuto è andato tutto a buon fine.
    rosgio67 - crwdns2934203:0crwdne2934203:0
    My machine did not switch to descaling mode after several tries. I ran it manually.
    Susan Jacobson - crwdns2934203:0crwdne2934203:0
    Istruzioni chiarissime. Grazie infinite
    Alessandro Contri - crwdns2934203:0crwdne2934203:0
    dopo aver completato l'iter di decalcificazione, è meglio fare un ciclo di pulizia semplice con acqua fredda, agire sul pulsante per 3 volte rapidamente.
    al comando del ritornare in modalità x fare il caffè la spia verde mi è ridiventata subito rossa! cosa fare?
    gabriella morroni - crwdns2934203:0crwdne2934203:0
    Desconecta por 15' y vuelve a enchufar a la corriente Haces un reset
    Mercè Feliu -
    Effettuato ora la decalcificazione come da indicazioni tutto a posto. Grazie
    Alessandro Teglia - crwdns2934203:0crwdne2934203:0
    A mi nunca se me para automáticamente la descalcificación ni el enjuague.
    Lo hago después de 1½ depósitos i salgo del paso
    Acabo de hacerlo con èxito
    A ciclo completato la spia è rimasta rossa e arancione. Cosa devo fare? Elena Pasquini
    Agatone 2020 - crwdns2934203:0crwdne2934203:0
    La spia rimane sempre rossa e arancione. Cosa fare in questo caso?
    Mada Madutza - crwdns2934203:0crwdne2934203:0
    Per uscire nuovamente dalla modalità di decalcificazione, tenere premuti contemporaneamente il pulsante e la leva per tre secondi.
    Martin - crwdns2934203:0crwdne2934203:0
crwdns2935229:043crwdne2935229:0
Olivia peet
crwdns2935283:002/15/21crwdne2935283:0
1 237 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S3-G18, Cowan Spring 2021 crwdns2935289:0Texas Tech, Team S3-G18, Cowan Spring 2021crwdne2935289:0
TTU-COWAN-S21S3G18
crwdns2947412:012crwdne2947412:0
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
James Spavelko - crwdns2934203:0crwdne2934203:0
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
Laura Retana -
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Attilio Carioti - crwdns2934203:0crwdne2934203:0
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Luca Levra -
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
maria.padovano1 - crwdns2934203:0crwdne2934203:0
Buona sera Maria, hai per caso risolto? ho lo stesso problema!
Guglielmo Pasetti -
Anche a me succede la stessa cosa...
Maurizio Gallone -
I ran the descaling liquid through but the red light was still there.. what should i do?
Valarie - crwdns2934203:0crwdne2934203:0
Vado nelle funzione , eroga una volta si ferma e poi nulla , lampeggia sempre color arancione ma nulla di nulla , ma bisogna intervenire manualmente o avviene tutto in automatico ?
Dopo la decalcificazione compare nuovamente la spia metà rossa e metà verde. Come si può risolvere?
Donato De Benedictis - crwdns2934203:0crwdne2934203:0
Have you tried the following?
To exit descaling mode again, press and hold the button and lever simultaneously for three seconds.
Hat prima geklappt 🤩vielen Dank!
monika flury - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 48
crwdns2936753:07crwdne2936753:0 288
crwdns2936753:030crwdne2936753:0 1,223
crwdns2942667:0crwdne2942667:0 208,989
