Has your coffee been tasting burnt or lacking flavor lately? Is your Nespresso running slow, or worse, not at all? If so, this guide is for you!
Over time, mineral deposits from water can accumulate inside your Nespresso Vertuo machine, affecting its performance and the quality of your coffee. Descaling is a crucial maintenance task that helps remove mineral buildup, ensuring that your machine functions optimally and continues to produce delicious coffee.
Whether you're a coffee enthusiast looking to maintain your machine's performance or a homeowner seeking to extend the lifespan of your appliance, this guide is designed to provide you with the knowledge and tools you need to descale your Nespresso Vertuo machine with confidence.
Lift the machine head to ensure there are no capsules present inside.
Empty the capsule container by removing it from the machine and disposing of any used capsules.
Fill the water tank halfway with fresh water.
Add 1 packet of the Nespresso descaling solution to the water tank.
To place the machine in descaling mode, begin with the lever in the unlocked position, parallel to the spout.
Press the button once and release it, then wait for the indicator light to turn on.
Press and hold the button until the indicator light turns off, and then begins blinking.
Rotate the lever to the left to secure it in the locked position.
Then return the lever back to the center to release the lock.
Press and hold the button until the indicator light turns off and then begins blinking again.
While the indicator light is blinking, rotate the lever to the left to place it in the locked position.
Place a large container (20oz+) underneath the spout.
Press and release the button once to begin dispensing the descaling solution.
Discard the solution.
Rinse out the water tank.
Refill the water tank until it's about two-thirds full of fresh water and place it back onto the machine.
Place the large container back under the spout.
Press and release the button one time to begin the rinsing process.
Once the machine is silent and the water tank is empty, discard the water from the large container.
To reset the machine for regular use, press and hold the button until the indicator light stops blinking.
Wipe the machine down.
Let the machine rest for 10 minutes.
By regularly descaling your Nespresso Vertuo machine, you are preserving its functionality and contributing to environmental sustainability. Keeping your machine in good working condition helps reduce the likelihood of it ending up in a landfill prematurely, minimizing the environmental impact of electronic waste.
To ensure optimal performance and longevity, Nespresso recommends descaling your machine every 3 months or 300 pods, whichever comes first.
Thank you for taking the time to follow this guide and for your commitment to maintaining your Nespresso machine. Here's to many more cups of great-tasting coffee!
