How to Descale a Keurig K-Mini
  1. How to Descale a Keurig K-Mini, How to Descale a Keurig K-Mini: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rinse and empty the water reservoir.
    • Make sure no k-cup is in the machine.
  2. How to Descale a Keurig K-Mini: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Descale a Keurig K-Mini: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Refill the reservoir with a solution that is about one-third distilled white vinegar and two-thirds water, to the MAX-fill line.
  3. How to Descale a Keurig K-Mini: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Descale a Keurig K-Mini: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Run a brewing cycle into a cup.
    • Empty the cup into the sink.
  4. How to Descale a Keurig K-Mini: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Refill the reservoir again with the same solution, and start another brew cycle, but this time once the machine starts dispensing the first couple drops, power off the machine.
    • Let the solution sit in the machine for an hour.
  5. How to Descale a Keurig K-Mini: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After an hour, hold the brew button down to empty the remaining solution from the water reservoir.
    • Avoid holding down the button too long after it is done dispensing, as you can potentially damage the water pump by forcing it to pump when there is no liquid left for it to pump.
    • Refill the reservoir with only fresh water, and repeat brew cycles to flush the solution out of the machine.
    • Repeat this process around 4-6 times to rinse the vinegar out of the machine.
    • If you taste any vinegar in your next brew, repeat the previous bullet.
Depending on how often you use your device, you should repeat this procedure about once every 3-6 months to maintain good tasting coffee.
Yusuf Barati
crwdns2935283:003/05/23crwdne2935283:0
163 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 60-1, Watkins Spring 2023 crwdns2935289:0Austin Community College, Team 60-1, Watkins Spring 2023crwdne2935289:0
AUSTINCC-WATKINS-S23S60G1
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,641
