How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker
  1. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker, How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker, How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker, How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the icemaker by pressing the power button.
    • Remove the ice from the machine using the provided scoop.
    • Either discard the ice into your sink or put it in a separate container to use later.
  2. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Either hold a container below the drain plug or place it over the edge of a sink.
    • Pull the plug quickly and let the machine fully drain.
    • To ensure as little spillage as possible, pull the plug and move your hand out of the way quickly.
  3. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a kitchen scale to measure your solution in fluid ounces.
    • Take your cleaning solution and pour about two ounces of solution into a container.
    • Make sure to balance your scale to 0 ounces before measuring by pressing the "tare" button while the container is on the scale.
    • If you’re using a different descaling solution than the Tupkee brand that is pictured, read the instructions for your solution to see the ratio of water to solution that is recommended.
  4. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Add the solution to one half gallon of filtered or distilled water.
    • Mix the 2 ounces of solution into the water.
    • 1/2 of a gallon of water is also approximately 1.9 liters.
  5. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the handle of the ice rack and remove it from the machine reservoir.
  6. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pour the solution and water mixture into the machine reservoir.
    • Press and hold the power button for 3-5 seconds until the indicator lights flash red simultaneously to start the self-cleaning cycle.
    • Only fill the reservoir to the max fill line. There will be a small amount of leftover solution and water mix.
  7. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As the self-cleaning cycle runs, use a toothbrush dipped in the cleaning mixture to remove any visible buildup in the machine.
    • Make sure to brush carefully and be mindful of the moving parts as to not break any small attachments.
  8. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the self-cleaning cycle is complete, drain the solution from the machine following the same procedure in Step 2.
    • You'll know the self-cleaning cycle has finished once the indicator lights stop flashing red.
  9. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pour clean, filtered or distilled water (without cleaning solution) into the machine reservoir.
    • Run the self-cleaning cycle again by holding the power button for 3-5 seconds.
  10. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the self-cleaning cycle with fresh water is complete, drain the solution from the machine following the same procedure in Step 2.
  11. How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Descale a AGLUCKY HZB-12/H Countertop Ice Maker: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Refill the machine reservoir with cool water and press the power button to run it as normal for clean ice.
We recommend repeating this descaling and cleaning process once every 2-6 months, depending on the hardness of water used in the machine.
justin hite
crwdns2935283:010/07/24crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
CSU Sacramento, Team 1-7, Laflen Fall 2024 crwdns2935289:0CSU Sacramento, Team 1-7, Laflen Fall 2024crwdne2935289:0
CSUSAC-LAFLEN-F24S1G7
Any information on diagnosing technical issues with the unit not making ice?
Working Man - crwdns2934203:0crwdne2934203:0
Hi there! It looks like the owner's manual has a short troubleshooting section: https://images.thdstatic.com/catalog/pdf...
If you don't find success there, I'd recommend posing the question in our Answers forum, with a bit more detail describing your exact issue: https://www.ifixit.com/Answers/Ask
We hope that helps!
Connor Bassolino -
I misplaced my owners manual so I was very happy to find this how-to information. The pictures and instructions were great and suitable even for persons with language barriers. Thank you so much.
Akilah McRoy - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 290
crwdns2942667:0crwdne2942667:0 2,405
