How to Darn a Sock
crwdns2942287:0crwdne2942287:0If you have a hole in your sock and want to fix it, this guide will help repair it through a simple method called darning.
Darning a hole in a sock provides a different outcome than simply sewing up the hole. When you darn a sock, it acts as a replacement for the missing fabric. So, if you have suitable thread types, you can create cool patchwork socks.
A darning mushroom is one of the tools listed. These can be found on Amazon or whichever website you use to purchase goods. If you do not have a darning mushroom or wish to avoid purchasing one, substitutes include tennis balls, light bulbs, or, like in my guide, a water bottle. Essentially, you will need an object inside the sock to stretch out the hole.
- Darning Mushroomcrwdns2942747:0crwdne2942747:0crwdns2943225:0crwdne2943225:0crwdns2931591:0Amazoncrwdne2931591:0
crwdns2944105:0crwdne2944105:0
Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
Sew a running stitch around the hole to reinforce it.
Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
Run parallel stitches until the hole is fully covered.
Rotate your sock 90 degrees, then repeat step 4 to create a patch.
Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
