If your 2002 Honda CR-V car door panels have peeled, they require repairing. When exposed to excessive heat or after having your vehicle for a long period of time, you may experience peeling panels. When panels peel, your car may not look like it once did. Fortunately, car door panels can be fixed in just a few steps. It is important to use appropriate tools and techniques to ensure a proper and seamless repair.
Clean the adhesive on the door panel using a wet cloth.
Use a different clean rag and add acetone to clean the area.
Cut out your chosen fabric to size and leave plenty of room for the sides.
Spray the entire panel with the adhesive.
Line up the fabric to the panel by starting in the center and pressing down gently.
Use an X-acto knife to push the fabric into the crevices.
Your car door panels should now be done. If these is still any peeling of the fabric, you can add more adhesive glue and press down on the panel.
