How to Connect LED Strip Lights
crwdns2942287:0crwdne2942287:0LED lights often don’t come with connectors and offer no way to connect them in a series to continues one strand. This guide shows exactly how to complete the steps to hang these on your wall connected in a series. This guide is useful for individuals who may purchase multiple sets of lights from different brands or the same brand that may not come with the correct connections. Often times, you receive two light strands with no way to connect them in sequence.
Attach one strand of lights using the pre applied glue or a hot glue gun where you desire.
Find the other side labeled RGB with prongs and/or wires and repeat the process from Step 1.
Using the prong side make sure both sides line up “RGB” to “RGB” on both sides.
Place each prong so it coordinates with the correct opposite plate.
Push towards the wall into the plate using the prongs and make a firm connection.
Using tape or hot glue firmly secure the center of the connection to the wall or desired area making sure there is little movement in the wires.
Turn on the light strip to make sure all the lights come on. Test to see if the colors change to make sure they all look correct and match each other.
I have no prongs on either end of my lights only plug ins
I broke the strip how do I fix it?
