How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clear a blocked, or clogged sink: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
Your sink should now be free of obstructions or clogs in the pipes.
Elijah Santiago
crwdns2935283:009/18/15crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-1, Prince Fall 2015 crwdns2935289:0Pasco Hernando, Team 5-1, Prince Fall 2015crwdne2935289:0
PHSC-PRINCE-F15S5G1
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 2,456
