How to Clean your iPhone's Lightning Port
  1. How to Clean your iPhone's Lightning Port, Inspect your charging port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean your iPhone's Lightning Port, Inspect your charging port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean your iPhone's Lightning Port, Inspect your charging port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Shine a flashlight into your charging port and inspect it for any large blockages.
    • A buildup of dust, grime, and lint inside the port can prevent the connector from fitting properly in the port.
    • Follow the guide normally to work your way through each procedure to thoroughly clean your port. Alternatively, click the links below to jump to a specific cleaning method:
    • Using a dust blower
    • Using a brush
    • Using isopropyl alcohol
    • Between cleanings, reinspect the charging port for any remaining blockages or missed spots.
  2. How to Clean your iPhone's Lightning Port, Blow air into the charging port: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clean your iPhone's Lightning Port, Blow air into the charging port: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Dust Blower
    • Don't use your mouth to blow into your charging port, as the moisture from your breath can damage the contacts.
    • Point the tip of a dust blower at one corner of the charging port.
    • This gives room for any debris to eject out of the charging port.
    • Blow a few puffs of air into the charging port.
    • Plug in your iPhone to check if it charges and if the charger is fully seated.
    • If your iPhone isn't charging or seats properly, unplug it and repeat the blowing process.
    • If your iPhone still doesn't charge or sits properly after multiple repetitions, move to the next step.
  3. How to Clean your iPhone's Lightning Port, Brush your charging port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean your iPhone's Lightning Port, Brush your charging port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean your iPhone's Lightning Port, Brush your charging port: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't use any metal tools to clean the port, as you risk damaging the port.
    • Insert the head of a brush, like a dry toothbrush, into the charging port.
    • Gently turn the brush in small circles to break up any clumped debris.
    • Remove the brush and use a dust blower to blow out any debris.
    • If any debris is stuck, reinsert the brush and rotate it to let the hairs "scoop" out any debris.
    • Plug in your iPhone and check if it's charging. If it's still not charging, move on to the next step.
    This brush was not included in the IFIXIT Precision Cleaning Kit.
    jcather - crwdns2934203:0crwdne2934203:0
  4. How to Clean your iPhone's Lightning Port, Clean the charging port with isopropyl alcohol: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean your iPhone's Lightning Port, Clean the charging port with isopropyl alcohol: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean your iPhone's Lightning Port, Clean the charging port with isopropyl alcohol: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow this guide to make a custom cotton swab.
    • You can also use dental picks with barbed tips (non-flavored).
    • You can use a normal cotton swab, but most are too thick and have loose cotton that can snag on the pins.
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) to the cotton.
    • Insert your tool into the charging port.
    • Don't force the tool into the charging port, as you risk bending the pins.
    • Slide the tool back and forth along the charging port to clean it.
    • Wait a few minutes for the isopropyl alcohol to evaporate before plugging in your iPhone and testing it.
  5. How to Clean your iPhone's Lightning Port, Test your iPhone: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug in your iPhone and check if it's charging:
    • If your iPhone is charging, congratulations!
    • If your iPhone isn't charging, repeat the isopropyl alcohol cleaning process.
    • If your iPhone still isn't charging after multiple cleaning attempts, and you confirmed with a flashlight that there's no debris, you may need to replace the charging port.
    • To replace your charging port, go to this page, find your iPhone's model, and follow the respective charging port guide for detailed instructions.
For other general electronics skills guides, click here.
crwdns2935229:018crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168 562 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021 113crwdne2935297:0
crwdns2947412:05crwdne2947412:0
The article on the Apple Support site says that compressed air should not be used: Cleaning your iPhone - Apple Support
WhiteDog - crwdns2934203:0crwdne2934203:0
Fair enough! I have changed the text accordingly.
Alex Diaz-Kokaisl -
Any understanding as to why compressed air would be harmful? The link simply says to not do it.
Matthew Bailey -
Apple is probably referring to the compressed air generated by shop compressors that may deliver a jet of air with exaggerated force. Alternatively, the blast generated by a spray can or a pump like the tool indicated does not cause damage.
Carmelo - crwdns2934203:0crwdne2934203:0
Bin voll und ganz begeistert. Mit Schritt 2 und Schritt 3 hatte ich Erfolg. Mein iPhone lädt jetzt wieder.
Werner - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 171
crwdns2936753:07crwdne2936753:0 1,408
crwdns2936753:030crwdne2936753:0 6,864
crwdns2942667:0crwdne2942667:0 95,961
