How to Clean the Panasonic DVD-RV31 Player Laser
crwdns2869540:0crwdne2869540:0: 9K
3
24
134
8.953
crwdns2955950:0crwdne2955950:0: 4
crwdns2960004:04crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 11
crwdns2959982:011crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 30 - 45 crwdns2931279:0crwdne2931279:0
This is a quick fix that can greatly improve, or fully restore, the ability to view DVDs with a Panasonic DVD-RV31 Player. Through normal use, a DVD player will get dirty and occasionally the laser's lens will need to be cleaned to restore functionality.
No special skills needed and nothing unusual about this repair; it should be easy to do and satisfying once completed! The only tool required is a microfiber or eyeglass cleaning cloth to be used on the lens to ensure it's not scratched in the cleaning.
    1. How to Clean the Panasonic DVD-RV31 Player Laser, Disk Tray Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Eject the disk tray from the DVD player before removing power supply.
    2. How to Clean the Panasonic DVD-RV31 Player Laser: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
    1. How to Clean the Panasonic DVD-RV31 Player Laser, Outer Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clean the Panasonic DVD-RV31 Player Laser, Outer Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
    2. How to Clean the Panasonic DVD-RV31 Player Laser: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
    1. How to Clean the Panasonic DVD-RV31 Player Laser, Front Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clean the Panasonic DVD-RV31 Player Laser, Front Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
    1. How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean the Panasonic DVD-RV31 Player Laser, Disk Drive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the four screws securing the disk drive assembly. There are two on each side.
      • Use a narrow screwdriver to remove all four screws.
      • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    2. How to Clean the Panasonic DVD-RV31 Player Laser: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift assembly by the front to pull metal bracket from the power board.
      • Pull up back end and lift drive out.
    3. How to Clean the Panasonic DVD-RV31 Player Laser: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
      • Lift bracket off and reserve for re-assembly.
    1. How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean the Panasonic DVD-RV31 Player Laser, Disc Retainer: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Grasp the bridge above the wheel and push the tabs on the side as shown.
      • Pull down firmly and away from the laser housing.
    1. How to Clean the Panasonic DVD-RV31 Player Laser, How to Clean the Panasonic DVD-RV31 Player Laser: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Microfiber Cleaning Cloths
      $3.99
      • Be sure to wash your hands before cleaning the optical laser lens.
      • Grab a microfiber or eyeglass cloth and gently brush the lens.
William
crwdns2935283:004/26/11crwdne2935283:0
283 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-20, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-20, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G20
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 134
crwdns2959996:0crwdne2959996:0 8,953
