How to Clean the Deck of a Greenworks M060L00
  1. How to Clean the Deck of a Greenworks M060L00, How to Clean the Deck of a Greenworks M060L00: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clean the Deck of a Greenworks M060L00, How to Clean the Deck of a Greenworks M060L00: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove battery and safety key.
    • Position the lawnmower on its side. Ensure the working surface is level and firm.
  2. How to Clean the Deck of a Greenworks M060L00: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Secure the lawnmower blade with a block of wood.
    • The lawnmower blade will want to rotate counterclockwise. Place the correct end of the blade against the wood block to avoid unnecessary blade rotation.
  3. How to Clean the Deck of a Greenworks M060L00: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bolt holding the lawnmower blade using a 17mm wrench or socket wrench.
    • Wear heavy work gloves if you are worried about working around a sharp lawnmower blade.
  4. How to Clean the Deck of a Greenworks M060L00: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic scraper to remove grass and debris from the underside of the lawnmower deck.
    • A metal scraper may damage the coating on the lawnmower allowing for rust to form.
  5. How to Clean the Deck of a Greenworks M060L00: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Optional: Use a brass brush to remove finer particles from lawn mower deck.
    • Brass brushes are soft enough to avoid scraping the protective coating. Use of a steel brush is not advised for this reason.
  6. How to Clean the Deck of a Greenworks M060L00: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the blade assembly. Hand tighten the lawnmower blade bolt.
  7. How to Clean the Deck of a Greenworks M060L00: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the blade is blocked to resist clockwise rotation.
    • Tighten the lawnmower bolt using a 17mm wrench or socket wrench.
    • Do not overtighten the lawnmower blade bolt. Overtightening could cause the bolt to crack.
Regular cleaning of your lawnmower is a simple task that allows the machine to run smoothly while increasing its lifespan. Electric lawnmowers cannot get wet, so using a power washer or hose makes the cleaning process slightly more involved. Despite this, it is still a relatively simple process that will make mowing your lawn a more enjoyable process.
Caleb
crwdns2935283:003/04/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 1-1, Kiser Spring 2025 crwdns2935289:0Colorado Springs, Team 1-1, Kiser Spring 2025crwdne2935289:0
UCCS-KISER-S25S1G1
crwdns2942667:0crwdne2942667:0 101
