Use this to clean the condenser coils in your Whirlpool Refrigerator.
The condenser coils dissipate heat during the cooling cycle. As dust and debris pile onto the coils, the fridge becomes less efficient and must work harder to cool down. If your refrigerator isn't cooling properly, your condenser coils might need some cleaning.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Turn off your main water supply
Unplug your device
Remove the screw(s) securing the rear panel.
Loosen the screw securing the water hose enough for the rear panel to freely move.
Pull the rear panel off the chassis to remove it.
Depending on your repair, open one or both doors.
Remove the screw(s) securing the front panel.
Pull the front panel straight off the chassis and remove it.
Vacuum any dust or debris clinging to the black condenser coils.
Repair didn’t go as planned? Ask our Answers community for help.
crwdns2917034:0crwdne2917034:0
Thanks for this, step 5 helped out a lot. I do have to say it is very frustrating trying to clean the coils on this model. The coils have that ‘V’ pattern all the way back which makes it really difficult to get a brush through. You almost need some type of access through the side to do this properly.
