Cleaning a snowblower’s carburetor helps to maintain its performance and prevent issues such as starting problems, fuel-related issues, and poor performance due to the buildup of debris and impurities in the fuel. Utilize this step-by-step guide as a resource to effectively maintain the carburetor for peak performance.
Make: YardWork
Model: LH3185A
Block the gas from coming out of the fuel tank using a locking plier.
Remove the stop key by pulling outwards.
Remove the choke key using a flat screwdriver.
Remove the two support bolts from the outer shield using an 8 mm socket.
Remove another two support bolts from the outer shield using a Phillips head screwdriver.
Loosen the handlebar by turning the knob counterclockwise until there's enough room to safely remove the shield.
Remove the inner switch using the 8mm socket.
Remove the bolt that holds the reservoir in place using a 13mm socket or spanner.
Remove the reservoir by pulling downwards.
Clean the jet nozzle (all three holes) using a pin or small wire.
Clean the inside of the reservoir, the rubber, and the jet using the carburetor cleaner.
