The Dyson Airwrap styler is a hair styling device that can be used to style hair through the use of heat. If your Dyson Airwrap styler experiences overheating, you may need to clean the air filter. This guide will show you how to clean the air filter on any 310731-01 model Dyson Airwrap styler. The process does not require any special tools or skills to complete, but if you are missing any parts of the styler, you can order them before starting the guide. Before beginning, make sure your styler is off and unplugged from any electrical outlet.
Unplug the Dyson Airwrap from the wall outlet.
Locate the filter cleaning brush.
Find the open side of the filter cleaning brush.
Thread it through the Dyson cord.
Pull the brush over the hair styler.
Rotate the bristles around the air filter.
While rotating the bristles, blow away any excess dust.
Gently pull the bottom air filter piece off of the hair styler, but do not pull it off the cord completely.
Gently rotate the filter cleaner brush around the exposed air filter.
Blow away any dust that may come off.
