After years of using your oven, various stains and residue often builds up and hinders visibility. This step-by-step guide will demonstrate how to clean the glass on your oven door and reduce visibility issues when cooking or baking.
The tools and supplies you will need within this guide are things most people already have within there household.
Before you begin, make sure that your oven is off. If you have used it recently, wait until it has cooled.
Now let's begin cleaning your clouded oven door!
Open the oven door until it lays flat.
Add a tablespoon of baking soda to a medium size bowl.
Pour 1 cup of vinegar into the bowl.
Mix the solution together.
Pour the mix on the open oven glass door, making sure to cover the entire area.
Leave it for about 45 minutes
30 minutes - 1 hour later, use a stainless steel sponge to scrub the glass door. The mix aids in loosening deep stains.
Once the stains are gone, use a towel to clean off the residue and remaining mixture.
Rinse the residue off the towel and repeat until the door is entirely clean of dirt and mixture residue.
Add soap and water to a sponge and gently clean the oven door.
Use a damp towel to wipe off the soap, then use a paper towel to thoroughly dry the oven glass door, ensuring there is no leftover water.
Enjoy you clean glass oven door!
