Use this guide to calibrate your Steam Deck's triggers from within SteamOS.
Valve recommends performing this software calibration after installing new triggers.
NOTE: Both Steam Deck thumbstick and trigger calibrations may not function in SteamOS version 3.3.
If you're not already in desktop mode, navigate to the Steam Menu → Power, and select Switch to Desktop.
Press the Steam Button + X to enable the on-screen keyboard.
From the Search menu, search for and open Konsole.
Within Konsole, type
trigger_cal
Press Enter.
I just tried this and get "command not found". Is it possible they have changed access since any updates? Desperately wanting to fix this and don't feel taking SD apart is issue. It feels like a calibration problem.
also getting command not found, can you please update this walkthrough so I can calibrate the trigger replacement I bought from you?
Ensure that neither trigger is depressed. Press Enter.
Tap on a blank desktop area to move the cursor off of the Konsole window. Make sure Konsole isn't in focus.
Gently press down each trigger until they bottom out.
Tap on the Konsole window to bring focus back to it. Press Enter.
That's it! Your triggers are now calibrated. The terminal should say "Trigger calibration successful."
Did not work and now the right trigger reacting same as left trigger. Tried multiply time and same happend
Click here to return to the left trigger replacement guide. Click here to return to the right trigger replacement guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
crwdns2935229:08crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Do you need to enable developer mode or download anything to get this working? All I get is 'command not found' when I try to run trigger_cal_v1_1.
Same, hoping this gets looked at and resolved.
all i get is :permission denied" anytime i try this, please update the guide
trigger_cal is located in /usr/bin/trigger_cal but is not executable. Here's what I did:cp /usr/bin/trigger_cal ~/
chmod u+x
./trigger_cal
This is an incomplete guide when it doesn't explain the permission error when executing trigger_cal
I just wanted to say thank you for this! I received a Steam Deck today and the right trigger was registering as if it were being pressed all the way down when it wasn't being touched at all. I was going to look into opening the Steam Deck and taking a look but the Konsole command Trigger_cal saved the day! THANK YOU AGAIN!
Few days ago I dropped my deck and the Left trigger broke. I glued with crazy glue and everything was "working fine" except for Marvel's Spiderman which didn't detect when I press L2 button.
Finally got the issue solved with this guide, calibration was missing... So definitely after modifying triggers, recalibrate them.
Thanks a lot for this, however when I want to do the same recalibration with my left bumper button, it doesn't work. I use the command 'bumper_cal' and I find it's wrong. So I truly want to know what is the correct command with bumper calibration?
Worked for me right away, no permission error, no developer mode had to be toggled on. In the device input test the right trigger wouldn't pull completely (32767 as the value) and it meant that left click in desktop mode was tricky to do (overpressing etc) but after this calibration it pulls properly! so happy :)
R2 Malfunctioning after steam deck turn on animation customization!?
This solved my problem!!!
Hey!!! I want to post this here for search engine reasons!!!
Recently, I downloaded a while bunch of cool new steam deck power on animations.
After downloading and seeing shuffle to on, my R2 button, uncalibrated, it's the only way to say it, I guess malfunctioned would work too.
Anyways, I saw this as I was looking into opening a steam support ticket, or just buying a replacement, as I had heard valve made them available.
Saw this recalibration thingy for after replacement, and, as my dilemma seemed to be a software issue, I tried it out, and it fixed my problem! I have my R2 functionality back!
Thank you for sharing this helpful info ifixit!
This solved an issue I had with the right trigger pressing constantly in game last night.
When I went to settings → Controller it was showing the right button “cycling”.
Exited to desktop, ran Konsole (terminal) and typed in “trig” & tabbed to autocomplete the command and it ran this, which fixed the issue after I ran through the prompts.
Thanks!
很棒的教程,我的steamdeck扳机问题解决了
Philip Kellett - crwdns2934203:0crwdne2934203:0
