How to Apply Custom-cut Battery Adhesive
  1. How to Apply Custom-cut Battery Adhesive, How to Apply Custom-cut Battery Adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any remaining adhesive from the phone frame, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  2. How to Apply Custom-cut Battery Adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Apply Custom-cut Battery Adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Apply Custom-cut Battery Adhesive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, figure out how the pre-cut adhesive strip should be oriented and which surface to attach it to.
    • If your pre-cut adhesive has pull tabs facing the center hole, the adhesive will attach to the phone's battery well first.
    • If your pre-cut adhesive strip has pull tabs on the outer perimeter, the adhesive will attach to the battery first.
    • Peel the clear plastic liner off of the pre-cut adhesive strip, exposing the adhesive.
    • Line up a long edge of the adhesive with the proper surface, as determined above.
    • Carefully set the adhesive down on the surface.
    • The adhesive is very sticky, so you have only one chance to align it.
    Test the battery before doing anything with adhesive. Also, the adhesive is entirely optional - it is NOT necessary for the phone to function well, as the battery is a tight enough fit not to wiggle any connectors loose.
    Miles Raymond - crwdns2934203:0crwdne2934203:0
    When I tried this, the adhesive stuck to the backing better than it did to the phone frame, and became tangled. I don’t see any way I could have prevented that.
    blicher - crwdns2934203:0crwdne2934203:0
    Für das Samsung S10 die dopplseitigen Klebestreifen (im Set die breiten) verwenden.
    Martin Thiel - crwdns2934203:0crwdne2934203:0
    As blicher said, the adhesive stuck to the blue film better than it did to the battery. So when I tried to peel the blue film, the adhesive came along with it. I had to use the tweezers to pull the adhesive off the film at one corner and carefully pull the film off while the tweezers held the adhesive to the battery. It didn't end up looking perfect, but it will hold fine I'm sure.
    Tom Wallace - crwdns2934203:0crwdne2934203:0
    Ich habe es ähnlich wie Bill (s. Schritt 3) gemacht und meinen Aufkleber-Rahmen in zwei Hälften (der Länge nach) zerschnitten. Weil der Rahmen etwas zu groß für mein S7 war, habe ich noch etwa zwei Millimeter quasi in der Mitte (dünne kurze Stege) entfernt und anschließend beide Teile getrennt angeklebt. Das ging sehr gut!
    LittleFix - crwdns2934203:0crwdne2934203:0
  3. How to Apply Custom-cut Battery Adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Apply Custom-cut Battery Adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the adhesive is aligned, use your fingers to press the adhesive into place.
    • When you are ready to stick the battery onto the frame, carefully peel away the blue plastic liner to expose the adhesive.
    • Set the battery lightly in place.
    • Plug in the battery connector temporarily to ensure that the cable reaches the socket.
    • Press the battery perimeter firmly with your fingers to help the adhesive bond.
    • Disconnect the battery before resuming re-assembly.
    the plug is actually not so easy to mount. luckily, I tried before removing the blue plastic liners. I ended up plugging the battery in before glueing it in place, just to be sure I could connect it at all, which worked fine for me.
    also, I recommend checking if the battery loads and whether the phone still works, before glueing the back cover on the phone
    Michael - crwdns2934203:0crwdne2934203:0
    Based on Michael’s comment above, I wanted to test to see how hard it was to electrically connect the battery. I am glad I did, as it would have been difficult to connect after the battery was mounted with adhesive (depending on where the battery sat within its compartment).
    My steps:
    1. Connect the battery electrically
    2. Cut the adhesive into a couple 1” strips, attach them to the back of the battery. (I tried to attach the whole adhesive to the battery and then pull the backing off, but it became kind of a hassle and didnt work too smoothly. I figured a couple strips would be adequate and it was)
    3. Press the battery into its compartment.
    Bill Slobotski - crwdns2934203:0crwdne2934203:0
    Danke für die Tipps! Sehr hilfreich! (Danke auch an Michael)
    LittleFix -
    The directions mention that the adhesive can be repositioned if it’s not aligned correctly. This was definitely not the case for me. Once I put the adhesive onto the battery, I noticed it was slightly off, so I tried to lift it up to reposition it, and it ended up stretching and then getting crumpled. Not too big a deal for the battery, but could be an issue for the case.
    Dennis - crwdns2934203:0crwdne2934203:0
    Hi Dennis,
    Thanks for the comment! I’ll adjust the instructions to include your findings.
    Arthur Shi -
    Replaced battery. Have always had success doing that on my Samsung phones, but this time when set to charge it flashes for about 5 seconds with the percentage sign not even zero percentage sign, and then it goes off for three seconds, on for 5 seconds off for 3 seconds, on for 5 seconds off for 3 seconds. I feel like it's trying to tell me something but what? no problem opening the phone back up again but hesitant to do so as obviously I was not successful with battery replacement. Any suggestions?
    Deborah B
    mummafor2@yahoo.com
    mummafor2 - crwdns2934203:0crwdne2934203:0
    Hi Deborah! Please post your question in our forum, where more people will see it and be able to help you.
    Arthur Shi -
    Place the battery by aligning the top to the top of the well, then put it down lightly.
    The battery (that I received) is slightly smaller than the well. Optionally, as in the 1st comments, first plug in the connector, test it with usb connect and powering on. Then usb disconnect and power off. You can leave the battery connected while placing carefully to ensure connectability.
    I placed the battery aligning the bottom side first, since that side was partly no adhesive, discovering a small gap between the top side of the battery and the well. The connector could not reach the socket. Luckily, the battery was not yet adhered that much and I could lift the battery again.
    Eduard - crwdns2934203:0crwdne2934203:0
    For me the battery connector could not be aligned properly once the battery was positioned in place due to torsion on the battery cable. You must first position the connector so it is square with the connector in the phone, press it in, and only THEN move the battery into its final resting place. When I did it that way it was easy. With the battery already in place (but not yet fully stuck), it was impossible.
    I agree you should connect the connector first. It has to be just in the right place, and also the length of the cable on the iFixit battery was slightly longer than on the original Samsung battery, so putting the battery back where the old one was didn't automatically put the cable in the right place. I had to hold the phone sideways and so I could watch the connector and the socket on the phone come together, and I had to bend the cable a little with the spudger. Then I installed the battery (using the original adhesive).
    Finally, there's absolutely no reason to "disconnect the battery before resuming re-assembly." The very next step (at least on a Samsung S10e) is to reinstall the midframe, which will cover the battery connector anyway.
    MikeT-NYC - crwdns2934203:0crwdne2934203:0
    i have the kit for the galaxy s10e, is there a guide specifically for that model as my kit doesn't have an adhesive that matches any of the above, just the precut adhesive card and the back panel adhesive
    Blue - crwdns2934203:0crwdne2934203:0
    S7: Ich habe den Stecker auch vor dem Einkleben ausprobiert. Tatsächlich passte mein neuer Akku perfekt rein, also nicht zu groß und nicht zu klein. Der Anschluss an den Steckplatz, also das flache "Kabel" mit dem Stecker musste ich etwas zur Seite biegen, es konnte nicht rechtwinklig einfach eingesteckt werden. Ich kann ebenfalls bestätigen, dass der Stecker schwer hinein ging. Ich habe dann trotzdem den Akku zuerst eingeklebt und dann den Stecker reingeklickt - allerdings war es nicht einfach und ich hatte Angst, ihn kaputt zu machen. Bis jetzt (halbe Stunde ;-) hält aber alles und der Akku lädt...
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:0162crwdne2935229:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
287,559 crwdns2915208:0crwdne2915208:0
crwdns2935297:0595crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,835crwdne2935297:0
crwdns2947412:022crwdne2947412:0
Fantastic job on the instructions ! I only wish I was able to find a solution, for removing the original glue from the back cover.
That is all I have left to do, and I have been unsuccessful for 6 to 8 hours of trying to find a way to get it off.
Lee Jones - crwdns2934203:0crwdne2934203:0
Hey Lee,
Your best chance is using high concentration (over 90%) isopropyl alcohol . If you can’t get the surface completely clean, that’s alright. Just try to get all large adhesive residue off, so that the battery and new adhesive will lie flat in the battery well.
Arthur Shi -
I accidentally rubbed off some of the black paste thing under the battery when cleaning it for the new battery adhesive strip. Should I be worried??
Henry Dang - crwdns2934203:0crwdne2934203:0
Hi Henry,
The black paste is possibly the graphite pad stuck onto the back of the display, which channels heat from the phone to dissipate through the display. There shouldn’t be any damage to your phone!
Arthur Shi -
Hi Arthur,
A big respect & thank you for the instruction to replace the battery. I couldn't be more happier because I did it myself thanks to you & ifixit team. It only took 30 minutes from start to finish. Just waiting on the back glass to arrive other wise excellent job on your side and awesome job to ifixit. I will have to buy higher concentration of isopropyl to wipe those big adhesive before I put the glass.
kar.kunal - crwdns2934203:0crwdne2934203:0
I’m glad to hear of your success! Keep fixing things!
Arthur Shi -
The Old Battery Connector SNAPS into place. but not the new battery i was sent. Could there be different Connectors??
Ted Fackelman - crwdns2934203:0crwdne2934203:0
Hey Ted,
This is a general guide for battery adhesive, so I can’t tell which phone you’re working on. Which phone are you replacing the battery for?
Arthur Shi -
91% percent isopropyl alcohol removes the residue very well. It is available at the local drug store about 2 dollars for a quart.
michael kotarba - crwdns2934203:0crwdne2934203:0
Greeting Arthur,
Thank you for the excellent, detailed instructions. I was able to replace my OEM battery without any problems. I do have a question related to charging the new battery. Your direction is: For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%. The instructions that IFIXIT sent with the kit was to allow it to run down to 10% then charge it to 100%. Is there a big difference here or are both methods okay?
Robert Fitzmaurice - crwdns2934203:0crwdne2934203:0
Hi Robert,
I’m glad you’re able to replace the battery! The proper way to calibrate the battery is to allow the device to run until it shuts off. This allows the battery management hardware to have a point of reference on what 0% is, and potentially reset any counter errors. For more details, check out this page.
Arthur Shi -
oops, forgot to clean off the old adhesive. is that going to be an issue? I already stuck on the new one...
Emily Lynn - crwdns2934203:0crwdne2934203:0
Hi Emily,
For the most part it should be fine, as long as there weren’t large uneven chunks of adhesive.
Arthur Shi -
I am unable to find adhesive tape for Galaxy s8 Active. Do you have a suggestion on what comparable tape might work on the s8 Active?
gboyles - crwdns2934203:0crwdne2934203:0
This is only half the work. The pictures don't match at all. Now that the glue strip is in, now what. What are these other strips for?
Jon Christensen - crwdns2934203:0crwdne2934203:0
I was directed here from the Samsung S6 battery removal. The images for the frame of this phone do not match the S6 that I have. Also, the parts and adhesives referenced here are not for the S6 either. This parts list show S7, S8, and S9 parts, implying this guide is NOT for S6 phones.
Also, there was no replacement adhesive for the front part that fits the frame in the kit sold from ifixit. The adhesive for the battery and back part seemed to be in the kit.
Samsung Galaxy S6 Battery Replacement
Micheal - crwdns2934203:0crwdne2934203:0
Hi Michael!
You're right—this is a general battery adhesive guide for Samsung phones. Your S6 will look differently from the images, but the procedure should be the same. I'll update the intro to reflect this.
Arthur Shi -
Thank you, Arthur. I also wasn't careful in reading, I assumed it would cover replacing the midframe also.
The battery guide didn't provide a guide for that procedure, and no adhesive replacement was issued with the repair kit.
I appreciate it!
Micheal -
Where can I get Galaxy S10 Battery Adhesive Strips?
Oliver Fallon - crwdns2934203:0crwdne2934203:0
While it's been 2.5 months and I doubt Oliver is still breathlessly awaiting an answer to this question, for the benefit of anyone else who may wander by in the future wondering the same thing:
For (possibly) every phone where iFixit has written a specific-model battery-replacement guide, up to (but not including) the S22 series, that guide has links to the battery adhesive for the model covered in the guide.
The reason the S22 series isn't included, AFAICT, is because starting with those models, Samsung themselves (finally!) sell self-repair kits/parts for the devices. So, iFixit doesn't sell the necessary adhesive, because it can be purchased direct from the manufacturer instead.
But the adhesive appears in the Parts list on the battery-replacement guide for at least the S10 Oliver was asking about, as well as the newer S21 models. (Those two and the S22/S23 were all I checked, sorry. I'm lazy.)
FeRD -
Hi, I'm replacing the battery in an S7 Edge using the ifixit kit. I have cleaned the site with alcohol and let it dry, then put the pre-cut battery adhesive in place and removed the blue plastic to expose the adhesive. Thr problem I have is that the battery does not stick to the adhesive, even after applying pressure. Can you suggest anything to help? My workshop is currently 12°C; is this too cold?
Alan Daniells - crwdns2934203:0crwdne2934203:0
Hi, I'm new here, for around 3 weeks ago my Samsung Galaxy S8+ died and did not want to start again or Charge at all, so I order from ifixit a new battery and repair set with a iOpener. But here is my problem now the problem is the same even with the new batter, 1 or 2 times the samsung logo qnd pop up when I start it, but it freeze and do nothing, forching me un plug the new battery, and after im back to square zero.
It was was 1 week ago I tried to fix it myself, but I don't know what my problem could be if it was the battery or it is something else, I have keft everything at my parents home because they have a bigger working space compare to mine, I think there is no idea to use the old ogrinal battery when I got the new one.
I hope someone can help me, but if there is no answer and if I had fix it myself than I would probably delete this comment.
DragonSkyNija@gmail.com - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 40
crwdns2936753:07crwdne2936753:0 260
crwdns2936753:030crwdne2936753:0 1,091
crwdns2942667:0crwdne2942667:0 108,651
