If you struggle to find jeans that fit perfectly on the waist, use this guide to alter the waist of jeans with a simple sewing method.
In step 4 of this guide, you will need to use a needle threader. For more detailed information on using a needle threader, follow the instructions on How to Use a Needle Threader.
Put on the jeans and pinch the extra fabric at the centre back of the waistband.
Mark both sides of the pinched fabric with chalk on the outside of the jeans.
Draw a diagonal line from each marked spot to the centre back seam.
Pass the thread through the loop on the needle threader.
Pull the needle threader out of the eye of the needle and create a knot at the end.
Begin sewing from the inside out, starting beside the belt loop.
Bring the needle across the marked spot and sew it inside out.
Move the needle horizontally, then insert and thread it through the fabric a short distance below the starting point.
Repeat this process until the thread reaches the centre back seam.
Pull the thread to conceal the stitches.
Bring the thread back to the inside of the jeans, tie a knot, and cut the excess thread.
Thank you very much for your help. You showed me a new way to tighten the waist on jeans
