This guide will show how to adjust the browning dial in a Black and Decker TR1278B toaster.
Remove the carriage lever by pulling it away from the toaster.
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
Detach the bottom from the front cover using the plastic opening tool.
Turn the toaster right side up.
Lift the front cover.
Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Unscrew the circuit behind the browning dial on the front cover.
Turn the knob on the circuit board left or right to adjust the browning dial.
In step 9 you are missing the plastic piece that goes into the hole next to the cancel button to index the position of the knob. No screws go in that spot.
