How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban
  1. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban, How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the wiring harness bundle, which exits the firewall underneath the brake booster.
  2. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the auxiliary wire, which is folded and taped to either the wiring harness or the fire wall.
  3. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a knife to cut the tape away from the wire and unravel it.
  4. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run the wire against the battery box.
  5. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the ring terminal (washer end) of the wire on the right post located at the front of the battery.
    • Place the 10 mm washer on the post.
    • Tighten the washer using a 10 mm wrench, crescent wrench, or pliers.
    • Post size and location may vary slightly in different models. The washer will fit snuggly around the correct post.
  6. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After hooking up the wire, check to make sure the 40 amp fuse is installed for the auxiliary pin.
    • If the fuse is not installed, there will be an empty space. This fuse can be purchased at any automotive shop.
crwdns2935229:014crwdne2935229:0
Lauryn Johnson
crwdns2935283:001/19/16crwdne2935283:0
478 crwdns2915208:0crwdne2915208:0
Oakland University, Team 6-14, Walwema Winter 2016 crwdns2935289:0Oakland University, Team 6-14, Walwema Winter 2016crwdne2935289:0
OAK-WALWEMA-W16S6G14
This sends constant power to the trailer. What if I wanted to make that power switched by the ignition so when the key is off I can be confident that the trailer won't kill my truck battery? I know I can just unplug the trailer harness or pull this fuse to stop it, but That might be easy to forget to do.
Eric Wonderlich Jr. - crwdns2934203:0crwdne2934203:0
Eric, did you ever get an answer to your inquiry about killing the power to the trailer when the key is in the off position?
Bobby Burke -
It’s not a break booster, it is a brake booster. If you are going to be an author, you should know the meaning of the words you use.
Albert - crwdns2934203:0crwdne2934203:0
Never fails some troll somewhere..
Garry Foster -
“Words have meaning” geez Cyber Warrior. Tough talk from a distance. ?
nshourds -
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 35,550
