How To Use And Maintain Your Coffee Grinder
    • Unplug the coffee grinder before any cleaning or maintenance to avoid electrical hazards.
    • Place the grinder on a stable, level surface away from moisture.
    • Add up to 50 grams of coffee beans to the grinder.
    • Grind for no more than 30 seconds to prevent overheating and preserve flavor.
    • Pause briefly between batches if you need to grind larger amounts.
    • Fill the grinder with a small amount of sugar for best results.
    • Run in short bursts and allow pauses to avoid melting the sugar.
    • Stop if you notice the motor heating or sugar clumping.
    • Use quick pulses to grind dry seeds such as poppy or sesame.
    • Consider adding a bit of sugar when grinding poppy seeds for smoother results.
    • Avoid grinding wet or oily foods in models without proper seals.
    • Remove and rinse the lid under water if the manufacturer allows.
    • Protect the motor housing by keeping it away from liquids.
    • Place a piece of slightly moist bread in the grinder and briefly run it.
    • Discard the bread to remove leftover coffee or sugar powder.
    • Use a small brush to clear any hidden spots around the blade.
    • Wipe the interior and blade shaft with a slightly damp cloth.
    • Clean away hardened sugar so the motor does not jam next time.
    • Wait until all parts are completely dry before grinding again.
Regular cleaning and careful handling will keep your coffee grinder running smoothly for a long time. Maintaining a safe environment, avoiding wet foods if not specified by the manufacturer, and preventing buildup are key to reliable performance.
Ula Gantar
crwdns2935283:001/08/25crwdne2935283:0
6,130 crwdns2915208:0crwdne2915208:0
crwdns2935297:038crwdne2935297:0
ZEOS Slovenia crwdns2935289:0ZEOS Sloveniacrwdne2935289:0
Local Repair Groups
crwdns2935297:044crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 38
