How To Service And Maintain Your Razor
    • Unplug the device or remove any batteries before beginning any maintenance.
    • Have a cleaning brush, isopropyl alcohol, and machine oil ready for servicing.
    • Take off the foil or blade assembly from the razor or trimmer as indicated by the manufacturer.
    • Check the mesh for damage or holes because a torn mesh could cause skin cuts.
    • Use a small brush or included cleaning tool to remove hair from the blades and housing.
    • Avoid using too much force on the foil or cutting surfaces to prevent damage.
    • Place the blade and any removable parts in a container of isopropyl alcohol to disinfect and dissolve residue.
    • Shift the moving parts gently by hand to help dislodge any trapped hair or debris.
    • Allow these components to dry completely before reassembly.
    • Place one or two drops of machine oil onto the moving parts and blade edges.
    • Activate the device briefly after reassembly to spread the lubricant evenly.
    • Wipe away any excess oil to prevent buildup.
    • Brush away any debrief.
    • Submerge only the removable blade assembly in isopropyl alcohol while the unit runs if the device is waterproof.
    • Rely on the vibrations to dislodge trapped hair or residue inside the blades.
    • Lubricate similarly with a few drops of machine oil and remove any excess.
    • Reattach the foil or blade assembly after all components have dried completely.
    • Switch the device on briefly to ensure smooth operation and correct alignment.
    • Schedule regular cleaning and lubrication sessions to extend the device’s lifespan.
    • Perform all work safely to support a circular economy and reduce electronic waste.
Your razor or trimmer should now be clean, lubricated, and ready for dependable use. By following these steps regularly, you minimize the risk of damage and maintain optimal performance. Always remember to review the manufacturer’s guidelines regarding maintenance to preserve your consumer rights.
Ula Gantar
crwdns2935283:001/08/25crwdne2935283:0
7,504 crwdns2915208:0crwdne2915208:0
crwdns2935297:045crwdne2935297:0
ZEOS Slovenia crwdns2935289:0ZEOS Sloveniacrwdne2935289:0
Local Repair Groups
crwdns2935297:052crwdne2935297:0
crwdns2942667:0crwdne2942667:0 82
