How To Reset a Suitcase Lock
Lisha Li
crwdns2944107:0crwdnd2944107:0Lisha Licrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 29, 2023crwdne2944111:0
5 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
For travel, luggage is an indispensable item. During the trip, we must set a password for the suitcase to ensure the safety of the contents. But the password can be easily forgotten and neglected, so opening the suitcase is a more difficult thing. If you do forget the combination, follow this guide to reset the combination on your suitcase lock.
  1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the suitcase down with the combination lock facing up.
  2. How To Reset a Suitcase Lock: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn a flashlight towards the lock, so that you can see the small details.
  3. How To Reset a Suitcase Lock: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Reset a Suitcase Lock: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Reset a Suitcase Lock: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the three gears together so that the grooved part of each gear faces the outside.
    • Correct: Gear faces the outside.
    • Gear faces the inside.
  4. How To Reset a Suitcase Lock: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remember the number of the three gears when the groove part is on the outside.
    • As of now the code number of the three gears is 181.
  5. How To Reset a Suitcase Lock: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
    • Turn the numbers on the lock to 636, and then unlock the lock.
  6. How To Reset a Suitcase Lock: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Reset a Suitcase Lock: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sometimes the difference is not 5 from the grooved spots. In this case, you can try to increase the numbers after adding 5.
    • For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
  7. How To Reset a Suitcase Lock: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Reset a Suitcase Lock: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When I added 8 and my number was 969, the lock unlocked. We successfully opened the suitcase!
    Hi . I tried the method . There are small little dent like thing ( ig groove ) on the 444 combination ( on each 4 4 4 gear ) . Then I started to add each gear by 1-9 simultaneously. But still It didn't open
    Kindly help
    Divyaditya Singh - crwdns2934203:0crwdne2934203:0
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
crwdns2935229:05crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Lisha Li
crwdns2935283:009/17/21crwdne2935283:0
445 crwdns2915208:0crwdne2915208:0
York University, Team E-11, Melo-Thaiss Fall 2021 crwdns2935289:0York University, Team E-11, Melo-Thaiss Fall 2021crwdne2935289:0
YORK-MELO-THAISS-F21SEG11
OMG! A big THANK YOU!!! It worked.
Edward Lee - crwdns2934203:0crwdne2934203:0
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
Chandrashekhar Dadhekar - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 32
crwdns2936753:07crwdne2936753:0 164
crwdns2936753:030crwdne2936753:0 696
crwdns2942667:0crwdne2942667:0 52,056
