How To Replace the Battery on a Conair Trimmer (GMT15NCS)
  1. How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two screws holding the trimmer blade in place.
    • Hold down the trimmer blades to make it easier to remove the screws.
  2. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift both of the trimmer blades off of the plastic guard.
  3. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the plastic guard from the casing by using the metal spudger tool.
    • Pry up at the top of the plastic guard, NOT the bottom.
  4. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the two screws inside the casing.
    • Tilt the trimmer to prevent the screws from falling into the casing.
  5. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the casing screw at the bottom of the trimmer.
    • Tilt the trimmer so gravity helps the screw fall out.
  6. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fire Hazard: Be careful not to stick the metal spudger too deep when prying to avoid puncturing the battery.
    • Separate the casing at the seam using the metal spudger to release the clips.
    • Use a twisting or prying motion, in any direction, to separate the casing.
    • The same process may be needed on the other side's seam to release clips.
  7. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws holding the battery setup in place.
    • Take note of the position of the positive and negative terminals of the battery on the setup.
  8. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery setup out of the casing.
    • Take note of how the battery setup lays in the casing.
  9. How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace the Battery on a Conair Trimmer (GMT15NCS): crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The soldering iron with be hot.
    • Using the soldering iron, desolder the battery at the connection to remove the battery from the setup.
    • Use iFixit's guide on How To Solder and Desolder Connections if you are not familiar using a soldering tool.
To reassemble your device, solder the new 2.4 V battery into the setup, and follow the instructions in reverse.
Nicholas Ellis
crwdns2935283:002/20/19crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S2-G6, Baddour Spring 2019 crwdns2935289:0University of Memphis, Team S2-G6, Baddour Spring 2019crwdne2935289:0
UM-BADDOUR-S19S2G6
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 12,009
