How To Replace The Drain Pump In Your Dishwasher
    • Unplug the dishwasher from the electrical outlet to prevent shock and damage.
    • Lay the dishwasher on its back to keep water from leaking onto internal parts.
    • Place a towel underneath to catch any residual water.
    • Identify the pump near the hose connection or in the center underside of the dishwasher.
    • Check your model’s layout since some pumps are positioned differently.
    • Some newer models use a simple twist-lock design instead of screws.
    • Loosen the hose clamp carefully to free the pump outlet connection.
    • Pull the pump assembly out from its mount once all fasteners are undone.
    • Check the impeller area for debris such as rubber bands or small items.
    • Clean away any blockage to see if the pump can function properly again.
    • Make sure that the pump rotates smoothly and is clean.
    • If you want to buy a new pump, take the old one to the store to make sure you get the right one with the correct connector.
    • Install the new pump or the cleaned original pump in the same position as before.
    • Return the dishwasher to its upright position and reconnect the power.
    • Run a test cycle to confirm water is draining and no leaks are present.
    • Ensure electrical connector and hose clamp are secured firmly without leaks.
If the dishwasher still fails to drain after reinstalling or replacing the pump, consult the manufacturer or an authorized technician. Always review your warranty documentation before attempting repairs. Working on electrical appliances carries risks, so seek professional help if you are uncertain. Properly maintaining your drain pump can extend the life of your dishwasher.
Ula Gantar
crwdns2935283:001/08/25crwdne2935283:0
7 504 crwdns2915208:0crwdne2915208:0
crwdns2935297:045crwdne2935297:0
ZEOS Slovenia crwdns2935289:0ZEOS Sloveniacrwdne2935289:0
Local Repair Groups
crwdns2935297:052crwdne2935297:0
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 811
