How To Replace The Condenser In Your Dryer
    • Unplug the dryer from the electrical outlet to ensure personal safety.
    • Check if the drum is not spinning and the clothes remain cold and wet after a cycle.
    • Listen for a strained motor sound as it tries to turn without enough support.
    • Recognize that a non-spinning drum can trigger a safety cutoff for the heating element.
    • Take out the condensation tank from the front compartment.
    • Locate and unscrew the two plastic screws in the tank area.
    • Remove the screws at the rear side of the dryer using a suitable screwdriver.
    • Lift and detach the top panel or cover once the fixing screws are out.
    • Look for additional screws along the edges and remove them carefully.
    • Gently lift and tilt the rear panel to reveal the internal components.
    • Verify the condenser is located next to the motor assembly.
    • Note that many dryers use an 8-microfarad condenser but confirm by checking the existing one.
    • Loosen the nut or bracket holding the condenser with a wrench or similar tool.
    • Unplug the short wires from the condenser terminals to free it.
    • Take note of the orientation and connection of wires for reference.
    • Position the replacement condenser in the same location and orientation as the old one.
    • Attach the wires to the correct terminals, ensuring secure contact.
    • Tighten the mounting bracket or nut by hand until it is firmly held.
    • Reattach all panels and screws in reverse order, ensuring a snug fit.
    • Restore power and briefly run a cycle to confirm normal drum rotation and heating.
    • Locate the thermal cutout near the heating element if the dryer stopped heating completely.
    • Check if it must be reset by pressing the small button on the cutout to restore normal function.
Replacing the condenser restores proper motor rotation and drying performance. Always follow your manufacturer’s instructions and be aware of warranty implications before making any repairs. If you encounter difficulties, consult a qualified service technician.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
449,349 crwdns2915208:0crwdne2915208:0
crwdns2935297:0252crwdne2935297:0
Staff
crwdns2935297:023,168crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 71
