How To Replace Burners on Weber Genesis II Grill
  1. How To Replace Burners on Weber Genesis II Grill, Burners: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill, Burners: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill, Burners: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is the Weber Genesis II grill. Before replacement of the burner, we will start by cleaning the grates with a grill brush in order to be clean and safe.
    • Make sure that the grill is completely turned off so there is no chance of accidental burn.
  2. How To Replace Burners on Weber Genesis II Grill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the grates using your hands.
    • Grab on each side of the grill grate with your hands and lift straight upwards.
    • Set the removed grate off to the side of the grill.
    • Repeat this procedure for all three of the grates on top of the grill.
  3. How To Replace Burners on Weber Genesis II Grill: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the heat deflector plates from on top of the burners.
    • Grab each deflector plate and pull straight upwards as with the grates.
    • Place the removed heat deflector plates off to the side of the grill.
    • Repeat this procedure for all heat deflector plates until each burner is exposed.
    • Only half of the heat deflectors plates will have burners underneath them. So do not be alarmed when not all plates have a burner.
  4. How To Replace Burners on Weber Genesis II Grill: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the burner from its slot in the back of the grill.
    • With both hands, carefully pull the burner upwards and slightly to the left in order to pull it out of its slot.
    • The burners can become stuck and require a little extra force to pull out, but do not pull too hard and hit the top of the grill or yourself.
    • If replacing all burners, repeat this procedure to remove all burners from their slots.
  5. How To Replace Burners on Weber Genesis II Grill: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Burners on Weber Genesis II Grill: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the burner from the ignition device.
    • With a small wedge, such as a flat-head screwdriver, unclip the white connector from the burner.
    • With the ignition device removed, you are now all set to replace the burner with a new one.
Nicholas Brown
crwdns2935283:003/24/21crwdne2935283:0
202 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G3, Riel Spring 2021 crwdns2935289:0UMass Dartmouth, Team S1-G3, Riel Spring 2021crwdne2935289:0
UMASSD-RIEL-S21S1G3
crwdns2936753:030crwdne2936753:0 80
crwdns2942667:0crwdne2942667:0 12,497
