How To Maintain And Care For Your Stick Blender
    • Unplug the stick blender before performing any maintenance or cleaning activities.
    • Avoid running the motor for long periods to prevent overheating and damage.
    • Utilize various container sizes, including jars, cups, or large pots for blending.
    • Be gentle in coated or glass containers to avoid scraping or breakage.
    • Grip the blender firmly and pivot your wrist left and right with gentle pressure up and down.
    • Keep movements smooth to reduce strain on the device and produce even blending.
    • Use pulsed bursts when blending soups or sauces directly in hot pots.
    • Keep the blades submerged to prevent splattering and potential burns.
    • Detach the blending shaft if applicable and rinse it under warm water with mild soap.
    • Swirl the lower end in a bowl of warm soapy water to remove stubborn debris.
    • Check the manual if the shaft is labeled dishwasher-safe for simpler cleaning.
    • Allow the stick blender to cool if it stops unexpectedly or overheats before continued use.
    • Contact authorized service providers if the device does not function after basic checks.
    • Dispose of or recycle the blender responsibly in accordance with local e-waste guidelines.
Following these guidelines helps keep your stick blender in good working order. Pausing to let the motor cool ensures longer life, and using appropriate containers prevents damage. Unplugging before any service and checking warranty restrictions helps keep you safe and protects your investment.
Ula Gantar
crwdns2935283:001/08/25crwdne2935283:0
7,534 crwdns2915208:0crwdne2915208:0
crwdns2935297:045crwdne2935297:0
ZEOS Slovenia crwdns2935289:0ZEOS Sloveniacrwdne2935289:0
Local Repair Groups
crwdns2935297:053crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 118
