How To Install Android on the Raspberry pi 4
crwdns2869540:0crwdne2869540:0: 57
2
6
30
57
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
Before diving into the installation guide, here are some important disclaimers
  • Unofficial Build: Running Android on Raspberry Pi is not supported by Google or Raspberry Pi Foundation.
  • Experimental Stability: Expect bugs, crashes, and missing features (e.g., hardware acceleration, camera, DRM apps).
  • Risk of Data Loss: Flashing images will erase your SD card. Back up important files first.
  • No Warranty: This may void warranties on your Pi or accessories. Proceed at your own risk.
  • Community Support Only: Help is available via forums and GitHub issues, not official support channels.
crwdns2936621:0crwdne2936621:0
      • Get a Raspberry Pi–compatible Android build (e.g., LineageOS for Raspberry Pi 4).
      • Use KonstaKANG’s LineageOS builds for Raspberry Pi 4: KonstaKANG LineageOS for Pi 4
      • Choose the latest .img.gz file (e.g., LineageOS 23.2 based on Android 16).
      • Option A: balenaEtcher
      • Download from etcher.balena.io.
      • Works on Windows, macOS, Linux. Simple “select image → select SD card → flash.
      • Option B: Raspberry Pi Imager
      • Download from raspberrypi.com/software.
      • Works on Windows, macOS, Linux and raspberry pi
      • Official tool, includes customization (Wi-Fi, SSH, hostname).
      • To install on Raspberry Pi OS, typesudo apt install rpi-imagerinto a terminal window
      • Insert microSD card (32GB+ recommended).
      • In Etcher/Imager
      • Select the LineageOS .img.gz file.
      • Select your SD card.
      • Click Flash and wait (5–15 minutes).
      • Insert SD card into Pi 4.
      • Connect HDMI, keyboard, mouse, and power.
      • First boot takes several minutes.
      • Follow the Android setup wizard (language, Wi-Fi, time zone).
      • Some builds don’t include Google Apps (Play Store, Gmail).
      • MindTheGapps
      • Official site: mindthegapps.com
      • Recommended for LineageOS builds (KonstaKANG specifically advises this).
      • Choose the correct version: ARM64 architecture and the same Android version as your LineageOS image (e.g., Android 12, 13, etc.).
      • OpenGApps
      • Official site: opengapps.org
      • Select: Platform = ARM64, Android version = your LineageOS build, Variant = “pico” or “nano” (smaller packages are safer for Pi).
      • Boot into Recovery
      • Most LineageOS builds for Pi include TWRP recovery.
      • On boot, hold Shift (or check KonstaKANG instructions) to enter recovery mode.
      • Transfer GApps Zip
      • Copy the downloaded .zip file onto your SD card or a USB drive.
      • Insert into Raspberry Pi.
      • Install via TWRP In TWRP, go to Install. Navigate to the GApps zip file. Swipe to confirm flash.
      • Reboot System After flashing, reboot into Android. First boot may take longer as GApps configure themselves.
By installing Android on a Raspberry Pi 4, you end up with a functional Android system that can run apps, connect to displays, and use USB or Bluetooth devices. With optional GApps, you also gain access to the Google Play Store for downloading apps. It’s not as fast as a phone or tablet, but it’s a fun, customizable project that gives you a cheap Android device for experimenting, learning, and DIY builds.
Shreyas vuyyuru
crwdns2935283:007/12/26crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2959996:0crwdne2959996:0 57
