How To Fix Dried Out Water Based Markers
  1. How To Fix Dried Out Water Based Markers, How To Fix Dried Out Water Based Markers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Obtain the items necessary.
    • 2 Tablespoons Of Vinegar
    • 3 Cups Of Warm Water
    • The Dried Out Water Based Marker
    • Make sure the marker is water based. If not, check the packaging if available. Steps 1-6 will not work on permanent markers. However, step 7 can be used for dried out permanent markers.
    • A Small Bowl
    • A Paper Towel
  2. How To Fix Dried Out Water Based Markers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Fix Dried Out Water Based Markers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Fix Dried Out Water Based Markers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fill the bowl with 3 cups of warm water.
    • You can use cold water - warm water allows for quicker solution.
    • Make sure the water is not boiling! It will ruin your marker!
    • Add 2 tablespoons of vinegar into the bowl with water.
    • Mix in the vinegar.
  3. How To Fix Dried Out Water Based Markers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Fix Dried Out Water Based Markers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Fix Dried Out Water Based Markers: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the marker tip down into the bowl.
    • Make sure the cap is off the marker. Set the cap aside for later use.
    • The marker can slip into the bowl. It just results in a longer drying time.
    • Allow the marker to sit for approximately 5 minutes in the water.
  4. How To Fix Dried Out Water Based Markers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Fix Dried Out Water Based Markers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Fix Dried Out Water Based Markers: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the marker from the bowl and place onto the paper towel.
    • Do not remove the marker until some ink is released into water.
    • Wrap the marker in the paper towel and allow it to sit.
    • Wait approximately two minutes.
  5. How To Fix Dried Out Water Based Markers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to place the cap back on the marker.
    • Make sure you lay the marker on its side.
    • Allow the marker to sit for up to 15 minutes before you start writing with it.
  6. How To Fix Dried Out Water Based Markers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pick up the marker and start writing.
    • Watch as the once dried out marker starts to work again.
  7. How To Fix Dried Out Water Based Markers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the marker does not work after steps 1-5, try placing the tip end in the vinegar alone and let sit in the vinegar for 2 minutes.
    • Do not be alarmed if some ink leaks into the vinegar, that is normal.
    • Allow the marker to dry for at least 15 minutes before you start using it.
Repeat as necessary for all water based markers.
crwdns2935229:021crwdne2935229:0
Kyle Ringler
crwdns2935283:004/09/15crwdne2935283:0
718 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-4, Green Spring 2015 crwdns2935289:0Cal Poly, Team 28-4, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S28G4
crwdns2931471:06crwdne2931471:0
crwdns2935297:017crwdne2935297:0
I had been throwing my dried up highlighters for years...thanks so much for sharing this info
Josephine Benjamin - crwdns2934203:0crwdne2934203:0
Works very, very well! Thank you, Kyle…
Melissa Herrera - crwdns2934203:0crwdne2934203:0
Agreed! Thank you so much still in 2021!
childofangel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 30
crwdns2936753:07crwdne2936753:0 234
crwdns2936753:030crwdne2936753:0 928
crwdns2942667:0crwdne2942667:0 96,148
