Use this guide to stop a leak in a common cartridge faucet.
Shut off the hot and cold water valves underneath the sink by twisting them clockwise until they are tight.
To test that the water has been completely shut off, try turning on the faucet like you would normally. If no water comes out, you're in luck!
Pull up on the the pop-up drain stopper to seal the sink drain.
Place a towel in the sink to catch any excess water or faucet hardware.
Use your fingers or a prying tool to remove the plug button from the top of the faucet handle.
Use a screwdriver to remove the single handle screw.
Gently pull the faucet handle up from the rest of the faucet.
Remove the temperature limit stop from the top of the cartridge.
Remove the temperature limit indexer from the top of the cartridge.
Use an adjustable wrench to loosen the bonnet nut.
I am looking for the brand of the faucet in this picture. We have one faucet and need aerator for it but no brand on it...?
