Full video tutorial here:
https://www.youtube.com/watch?v=dXekEleH...
TIMESTAMPS: 00:00 - Intro 00:10 - Items You Need 00:40 - Important Note 00:50 - Background & Thanks 01:30 - Types of Syscon 02:00 - Check Your PS3 Model 02:15 - Console / Board Revisions 02:48 - Mullion Extra Solder Point 03:07 - Prepare Wiring 03:49 - Mullion Diagrams Start Here 03:53 - COK.001/002 (Mullion) 04:12 - SEM.001 (Mullion) 04:30 - DIA.001/002 (Mullion) 04:46 - Sherwood Diagrams Start Here 04:58 - VER.001 (Sherwood) 05:03 - DYN.001 (Sherwood) 05:07 - SUR.001 (Sherwood) 05:12 - JTP.001 (Sherwood) 05:17 - JSD.001 (Sherwood) 05:21 - KTE.001 (Sherwood) 05:24 - NOTE ! SUPER SLIM 05:39 - Partially Re-Assemble Console 06:08 - USB ADAPTER WARNING 06:37 - Driver Install 06:50 - Check COM Port 07:41 - Connect UART 08:20 - Enable Internal Mode ( Mullion ONLY! ) 11:10 - Fix Checksum ( Mullion ONLY! ) 12:53 - Sherwood Connection ONLY 13:41 - Syscon Software ( ALL SYSTEMS ) 14:13 - Useful Commands 14:49 - Close up Console 15:00 - How to ask for Help 15:14 - Common Error Codes
There are some notes here, the GUI version you have listed will not give the full bringup for syscon, this doesn’t give people enough accurate data to see what exactly is going on, I would recommend you link RIP-Felix’s video as well as that has more in depth explanation on the python version of syscon which is more reliable than the GUI, it’s a good video but I would definitely go with the python version over the GUI just from how many bugs I have had in the past with that
Also I forgot to mention it would also be nice to have a step by step guide written out so people don’t have to refer to a video for guidance, there are people who would rather read along and have the video as a backup than have only a video
Mi ps3 fat pasa esto cuando yo soluciono el juego como gta 5 ohh wwe 16 etc se me ve algunas veces la pantalla en negra ohh cuando inicia cuando estoy jugando en esos juego que dije a los 20 minutos se me apaga pero cuando entro al fifa no se me apaga porque sera ? Si dicen que es por mantenimiento ya esta limpia de polvo y la pasta termica
It’s more than likely going to be tokins but without the syscon logs it’s hard to say, you don’t have to follow this guide, you can use ps3toolset.com to get your codes if your console boots.
Mi ps3 se apaga a cabo de unos 20 minutos
Qué será!?
