You will need a T5 and a PH000 tip from the iFixit's kit.
If the camera is taking fuzzy pictures it may be due to debris blocking the lens.
Slide the battery cover to the right.
Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
Remove the batteries by gently tipping the camera.
Remove the four screws the hold the back of the case to the rest of the camera.
Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
Remove back case from the rest of the camera carefully.
Remove the three screws the secure the motherboard to the front case.
Remove the motherboard from the front case.
Leave the red and black wire attached but lay the piece in front of the case.
Wipe the lens and the clear plastic on the front case to remove debris.
crwdns2917034:0crwdne2917034:0
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
