This guide shows how to change the engine oil in your 2018-2024 Toyota Camry equipped with the 2.5 L 4-cylinder.
Oil is essential to the operation of the engine in your eighth‑generation Camry.
Low or dirty oil will cause increased exhaust emissions and more internal wear, shortening the engine's life.
Follow this guide to drain the old oil, install a new filter, add new oil, and reset the service light.
crwdns2931653:01crwdne2931653:0 Gather tools parts and safety gear
Collect 0W16 engine oil, a new oil filter and a fresh drain plug washer.
Have a ratchet, 10 mm and 14 mm sockets and a socket extension ready.
Prepare wheel chocks, a hydraulic jack, jack stands and an oil drain pan.
Put on safety glasses and protective gloves and keep rags and paper towels handy.
crwdns2931653:02crwdne2931653:0 Raise and secure the vehicle
Engage the parking brake and place wheel chocks behind the rear tires.
Position the hydraulic jack at the front jack point and raise the vehicle.
Slide jack stands under the rocker panel pinch welds and lower the car onto them.
crwdns2931653:03crwdne2931653:0 Prepare the filter and drain plug
Use a marker to draw four evenly spaced marks on the new oil filter circumference.
Slide a new crush washer onto the drain plug with the flat side toward the bolt tip.
Remove the oil filler cap on top of the engine to aid draining.
crwdns2931653:04crwdne2931653:0 Remove the under‑tray
Using a 10 mm socket and extension remove the screws securing the small drain‑pan cover.
crwdns2931653:05crwdne2931653:0 Drain the engine oil
Place the drain pan under the 14 mm drain plug.
Use the 14 mm socket and ratchet to break the plug loose, then finish unscrewing it by hand.
Let the oil flow until it slows to a steady drip.
crwdns2931653:06crwdne2931653:0 Reinstall the drain plug
Check that the old crush washer is not stuck to the pan and wipe the sealing surface clean.
Fit the new washer on the plug as oriented earlier and thread the plug in by hand.
crwdns2931653:07crwdne2931653:0 Replace the oil filter
Spin off the old oil filter and let residual oil drain into the pan.
Clean the sealing surface on the engine with a rag.
Screw the new marked filter on until the gasket touches the housing.
Hand‑tighten the filter roughly three‑quarters of a turn using a rag for grip if needed.
crwdns2931653:08crwdne2931653:0 Reinstall the under‑tray
Refit the plastic cover and hold it in place.
Use the 10 mm socket with the extension without the ratchet to tighten the screws by hand.
crwdns2931653:09crwdne2931653:0 Add fresh engine oil
Pour 4.8 quarts of 0W16 oil into the engine through the filler neck.
Reinstall and tighten the oil filler cap.
crwdns2931653:010crwdne2931653:0 Check the oil level
Press the engine cover back onto its mounting pins.
Pull the dipstick wipe it clean reinsert it and verify the second reading.
crwdns2931653:011crwdne2931653:0 Reset the maintenance reminder
Start the car and open Vehicle Settings with the steering‑wheel controls.
Select Scheduled Maintenance choose Reset Data and confirm the prompt.
Dispose of the used oil and filter at a recycling facility or local parts store, then record the mileage and date of your service so you know when the next change is due.
Most AutoZone stores accept used motor oil.
Oil change didn't go as planned? Ask our Answers community for help.
