Use this guide to replace the Bluetooth remote control of a Hoverboard.
Be careful! A soldering iron is used in this guide, so take the necessary precautions before starting
Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
Unhook the lighting and indicator light wires to remove the cover.
Remove the 4 screws that hold the circuit board support.
Remove the 4 screws that secure the board to the support.
Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
To reassemble your device, Follow these instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
