Hover-1 XLS Battery Replacement
  1. Hover-1 XLS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 XLS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 XLS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
    • There are four screws that need to remove. Two on one side and the two on the opposite side.
    Hi,
    I can't find this battery anymore.
    Planning to assemble my own set of batteries,
    Can you tell me the yellow and white wires NTC wires or communication wires?
    Tks
    realceragx - crwdns2934203:0crwdne2934203:0
  2. Hover-1 XLS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 XLS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 XLS Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the adhesive holding the wires tightly.
    • You can use a sharp object to score the adhesive before pulling.
    • Pull on both sides of the wire connections.
    Battery needed ....where did you find it
    Ryan - crwdns2934203:0crwdne2934203:0
    I’m also looking for this battery. I Emailed hover-1 they said they do sell it.
    Can anyone give me an idea of where to go to get this battery.
    Thanks
    Cprenaveau@gmail.com
    Chris
    Chris P - crwdns2934203:0crwdne2934203:0
Jonathan Hidalgo
crwdns2935283:001/24/19crwdne2935283:0
596 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G2, White Winter 2019 crwdns2935289:0Cal Poly, Team S1-G2, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S1G2
crwdns2947412:015crwdne2947412:0
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - crwdns2934203:0crwdne2934203:0
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk -
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - crwdns2934203:0crwdne2934203:0
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King -
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - crwdns2934203:0crwdne2934203:0
has anyone been able to find the battery replacement ? any links ?
Fabulous P - crwdns2934203:0crwdne2934203:0
I agree 100% dam Battery is impossible to find with the same Plugs
Mike Jones -
Cannot find a battery ANYWHERE. Looks like I'm replacing the scooter with a more reputable brand like Segway
skyyballer - crwdns2934203:0crwdne2934203:0
Wow, so I’m not the only one that’s having trouble finding a battery. %#*@ that sucks. I even went as far as trying to contact the maker of the battery, but none of the websites in English,
Justin Cerrato - crwdns2934203:0crwdne2934203:0
Try checking this out because the batteries aren’t branded by Hover-1:
Possible Compatible Battery
I hope it helps someone… It’s pretty expensive but it’s the closest I’ve found so far. Compare it with your battery and see if it’s the same. Good luck!
Don Chunome - crwdns2934203:0crwdne2934203:0
My battery is not in this location other is a control box. the fat bar that is attached to the front forks and goes to the rear wheels has 4 screws at the front. I removed them and tried to take top cover off. Cover would not come off. I read that you cannot remove battery. Do u have a clue? Thanks Tommy
Thomas Watts - crwdns2934203:0crwdne2934203:0
Thomas Watts I meant to say where u say the battery is located in the front forks when I removed the cover my scooter has a control box. Where else could battery be at. Like I said the cross bar from the front forks to rear wheel would be the only other place and when I removed the 4 screws I could not get cover off. It was a new present gifted to me. Has never been abused. It is as new condition. I am trying to locate Manuel that came with it. Thanks
I am having the same problems! Did you find the manual? How about a battery replacement?
Nash Robinson - crwdns2934203:0crwdne2934203:0
I need new battery to find with same plug please supply new battery I will any cost
Hitesh Shah - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 217
crwdns2942667:0crwdne2942667:0 10,923
