Hover-1 Titan Right Gyroscope Replacement
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the cable tie and unplug the remaining wires.
Jessica Ouyang
crwdns2935283:010/08/18crwdne2935283:0
619 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G4, White Fall 2018 crwdns2935289:0Cal Poly, Team S15-G4, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S15G4
Where can I get the circuit boards for the left and right ?
jfsucher - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,353
