Hover-1 Rally Rear Wheel Replacement
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
    The bit for the screwdriver is a hex/allen bit, not a Phillips.
    Dylan Ruiz - crwdns2934203:0crwdne2934203:0
    You don’t need to specify which direction to turn the screwdriver to remove the screw.
    Jason Pagendarm - crwdns2934203:0crwdne2934203:0
  2. Hover-1 Rally Rear Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
    Instead of remove say slide. It is more descriptive.
  3. Hover-1 Rally Rear Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Rally Rear Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
    What is the size(diameter) of the axle?
    AverageRedHead - crwdns2934203:0crwdne2934203:0
  4. Hover-1 Rally Rear Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
Cami Lowrey
crwdns2935283:002/07/20crwdne2935283:0
441 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G2, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S7-G2, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S7G2
crwdns2931471:06crwdne2931471:0
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,098
