Hover-1 Rally Brake Pad Replacement
  1. Hover-1 Rally Brake Pad Replacement, Rear Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Brake Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Brake Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Rally Brake Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Brake Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
  5. Hover-1 Rally Brake Pad Replacement, Brake Pad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by removing the two 8.0 mm screws from the deck using the Phillips #2 screwdriver.
    • Two screw caps will come off with the screws
  6. Hover-1 Rally Brake Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the foot brake/ wheel cover away from the deck and downwards.
  7. Hover-1 Rally Brake Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the foot brake, remove the two 8.0 mm screws using the Phillips #2 screwdriver.
  8. Hover-1 Rally Brake Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the opposite side of the brake, remove the silver brake pad.
    • If this is your first time replacing this part, the removal might require more force. You may need to use the flat end of a spudger to pry it off.
Elizabeth Picazo
crwdns2935283:002/12/20crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G2, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S7-G2, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S7G2
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 658
