Hover-1 Nomad Speaker Assembly Replacement
  1. Hover-1 Nomad Speaker Assembly Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad Speaker Assembly Replacement, Speaker Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement, Speaker Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 13mm Phillips #1 screws in the corners of the speaker assembly circuit board.
    • You cannot fully disconnect the circuit board from the speaker. Set it aside for now.
  6. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 13mm Phillips #1 screws fastening the speaker retention bracket to the shell.
  7. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker retention bracket up and off the speaker.
  8. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Break the glue connecting the speaker to the outer shell by prying the speaker up with a nylon spudger.
    • Lift the speaker off the outer shell.
  9. Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Nomad Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to scrape the fabric speaker cover off the outer shell.
    • Peel the fabric off the outer shell.
    • New speakers and fabric will already be glued together. Apply the whole assembly to the outer shell at once during reassembly.
Samuel Frazee
crwdns2935283:010/08/18crwdne2935283:0
1.015 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G1, White Fall 2018 crwdns2935289:0Cal Poly, Team S15-G1, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S15G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 338
