If the hoverboard is unwilling to move and it is fully charged, there may be an issue with the wheel motors.
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove the bottom cover by lifting it away from the hoverboard.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Place the hoverboard so the sensor boards face you.
Remove battery connector by pulling it apart.
Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
Disconnect the colored wires by pulling them apart.
Hola buenos dias, sabes que requiero las carcasas de este mismo modelo, tendrás?
Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
Remove the four 10mm screws with a Phillips #1 screwdriver.
Remove the sensor board by lifting it away from the hoverboard.
Place the hoverboard so the four 36mm Allen bolts are pointing up.
Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
Lift the metal retaining plate away from the motor shaft.
Lift motor assembly away from hoverboard.
My bracket the wheel attaches to hoverboard is broke can that portion of board be replaced? Where can I buy it if so?
Can I buy a replacement battery side motor for hover1 drive hoverboard. If so, where? Can’t seem to find it on internet
