Hover-1 Liberty Wheel Motor Replacement
  1. Hover-1 Liberty Wheel Motor Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Wheel Motor Replacement, Gyroscope Sensor Boards: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the hoverboard so the sensor boards face you.
    Where can you purchase the replacement boards?
    jparram - crwdns2934203:0crwdne2934203:0
  5. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
    Hola buenos dias, sabes que requiero las carcasas de este mismo modelo, tendrás?
    Hugo Villaverde - crwdns2934203:0crwdne2934203:0
  6. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
  7. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
  8. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
  9. Hover-1 Liberty Wheel Motor Replacement, Wheel Motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement, Wheel Motor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the hoverboard so the four 36mm Allen bolts are pointing up.
    • Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
    • The four Allen bolts have lock washers.
  10. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the metal retaining plate away from the motor shaft.
  11. Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Liberty Wheel Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift motor assembly away from hoverboard.
    • There is a flat section on the motor shaft that needs to point up, towards metal plate.
    • The motor assembly should be flush with side of hoverboard.
    Where can you purchase replacement motors?
    luke-1115@hotmail.com - crwdns2934203:0crwdne2934203:0
Eduardo Miranda
crwdns2935283:010/08/18crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G2, White Fall 2018 crwdns2935289:0Cal Poly, Team S13-G2, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S13G2
My bracket the wheel attaches to hoverboard is broke can that portion of board be replaced? Where can I buy it if so?
Adam Vernengo - crwdns2934203:0crwdne2934203:0
Can I buy a replacement battery side motor for hover1 drive hoverboard. If so, where? Can’t seem to find it on internet
crwdns2942667:0crwdne2942667:0 5,274
