Hover-1 Liberty Gyroscope Sensor Boards Replacement
crwdns2942287:0crwdne2942287:0If your hoverboard is experiencing issues where it will not move forward or unable to maintain balance, there is a problem with the gyroscope controlling the wheels.
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove the bottom cover by lifting it away from the hoverboard.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Place the hoverboard so the sensor boards face you.
Remove battery connector by pulling it apart.
Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
Disconnect the colored wires by pulling them apart.
Hola buenos dias, sabes que requiero las carcasas de este mismo modelo, tendrás?
Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
Remove the four 10mm screws with a Phillips #1 screwdriver.
Remove the sensor board by lifting it away from the hoverboard.
crwdns2947412:09crwdne2947412:0
Where can you purchase the replacement board for the Hover-1 liberty?
Where do you get replacement board?
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Make this site useful by telling us where we can buy a new circuit board.
Where do you get circuit board from.
I am looking for the Hover 1 Nova YS-SXT-V4.2a board where can I find it. davewms@santel.net
Hello Eduardo. Please can you tell me who sells specifically this version of the controller boards ?
Hi all, do you know where I can buy a Hover-1 Rocker Gyroscope Sensor Boards?
Thanks Peter
I replaced motherboard and gyroscope still have a red light on one side green on battery side
